586,675 active members*
2,857 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma LC10 OSP3000L G commands dosn't work with S commands
Results 1 to 8 of 8
    Jun 2020
    6
    I have okuma lc10, but G commands dosnt work toghether with S command
    Here is a example if i type:
    G14
    S400M3
    G0 X20
    Spindle will start rotate but g funcion will not work without any error,
    But if i type just G command in MDI it works.
    Mar 2009
    1982
    Re: Okuma LC10 OSP3000L G commands dosn't work with S commands
    check if spindle rpm reaches the desired level.
    Look into the programming manual if there is G code ( or maybe M ) to execute the command without confirmation if previous command completed. It is marked as dangerous command. Used mostly to index turret without confirmation the turret indexing ( limit ) position.
    Try reduce spindle speed.
    If there is spidle gear switching in your machine? try another gear for the spindle speed.
    Apr 2006
    822
    Quote Originally Posted by Aksa View Post
    G14
    S400M3
    G0 X20
    Can you please post ALL alarms that come up?
    Will it make any difference if you are in Single Block mode or not?
    Jun 2020
    6
    Quote Originally Posted by broby View Post
    Nope, and there is no alarms i just had chuck clamp alarm but i fixed it
    Jun 2020
    6
    Quote Originally Posted by Algirdas View Post
    I was trying to find that m command but i cant find it in manuals
    Mar 2009
    1982
    check if it is related to spindle rotation speed first. Reduce RPM, try dwell command ( G04 ? ) before G0.
    there are more places where root of problem can be. For instance, try G0 without spindle command. Try Rapid feederate override knob or command.
    Find the screen where details of command execution are shown. Is there remaining distance, positioning speed indicated?
    Check if G01 is working correct.
    Jun 2020
    6
    G01 not working as well
    G0 work without spindle command
    Mar 2009
    1982
    execute the G code command "feed per minute". Maybe then G01 starts to work.
    The reason can be in the global mode "feed per revolution" now.
