586,974 active members*
2,958 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Stepper Motor making noise but not moving
Threaded View
    Jan 2021
    Question Stepper Motor making noise but not moving
    Need Help !!!
    I have an Alpha 42hs60-15a4 motor and it is connected to a4988 driver, it set to 0.6 current limit, connected to 15v 10 amp power supply, A CNC shield used to control the motors and i already uploaded grbl on an arduino uno and start using universal gcode sender to control of the axes associated with motors, But when sending a signal from the gcode sender software motors start making noise instead of spinning.
    i have already weird it as it should bd and i have tested 2 cnc shield on the same circut
    Attached Thumbnails Attached Thumbnails 137041093_136538354834278_4054381948148345058_n.jpg   136939166_156495746251308_6886104755064038890_n.jpg
