586,525 active members*
3,390 visitors online*
    Dec 2007
    578
    413 CPU Failure
    Hello all,
    I have an older Centroid control on a ACER knee mill. Today i got this error twice, 413 CPU Failure #01. One failure happened when machine was sitting idle with Estop active. The manual says the reason is "CPU10 has experienced a problem with the PC reset line. Z80 Failure. Problem with the ZiLOG chip."
    Anyone experienced this before? Is this a chip that can be replaced?
    Software Version:
    CNC10 Mill v2.64
    Thanks for any info,
    Troy
    Aug 2016
    16
    Re: 413 CPU Failure
    The first thing to try is cleaning the card edge fingers and motherboard slot and re-plugging several times time make sure the connection is good.
    The board is fairly complex, so anything beyond that is not DIY friendly.
    The chance of the actual IC being bad is near zero. The problem is most likely some bad connection to the IC or supporting components preventing it from running.
    Dec 2007
    578
    Re: 413 CPU Failure
    I tried re seating card a few times after i started this thread, and so far all is good. Thanks for the re assurance of the fix.
    Troy
    Nov 2022
    12
    Re: 413 CPU Failure
    Please help me by giving me a link to where I chasebank atm near me
    download the Kollmorgen Drive Motionlink software
  1. VFD failure
    By dbunyip in forum Tormach Personal CNC Mill
    Last Post: 12-19-2017, 09:26 PM
  2. Nobody knows? Big Problem with 20/50 Failure 119
    By Bgkai2 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-30-2015, 02:51 PM
  3. Help -- what to do in power failure?
    By robedney in forum DIY CNC Router Table Machines
    Last Post: 04-20-2013, 06:48 AM
  4. MDI / RAP failure
    By s&swelding in forum Cincinnati CNC
    Last Post: 04-30-2010, 07:24 PM
  5. VB System Failure??
    By kbillan in forum Machines running Mach Software
    Last Post: 11-20-2008, 01:01 AM
