587,035 active members*
3,102 visitors online*
Results 1 to 9 of 9
    Aug 2012
    Marking lots of anodized parts/which machine?
    Hello everyone,
    I would like to first say that I know very little about lasers but very knowledgeable around CnC machines.
    We are looking for a machine that will strictly be marking anodized aluminum with our company logo and such. We are looking to mark lots of parts and trying to not only find a fast machine but one that will do a decent amount of parts at one time. I think we want something that is 24x36" at minimum. I have been told that CO2 would be the way to go and not to get anything over a 80W. Just trying to learn a little more about what machines i should be looking at for our particular situation/need. Thank you for any help you may offer.
    Nov 2015
    371
    Re: Marking lots of anodized parts/which machine?
    You need a gantry fiber laser machine. All majo brands make them. Here are the top 3 options:
    - Epilog Fusion Pro 48
    - Trotec Speedy 360 Flexx
    - GCC S290LS
    It may be a good idea to add a camera for precise positioning of the graphics.
    If the cycle time is very important for you check the option for a gantry machine equipped with a galvo head. The speed and the engraving quality will be significantly better. It will have to be a custom made machine. Most likely you will have to import it from China.
    Aug 2015
    142
    Fiber laser are more expensie than co2 and i think a co2 laser will do same work , but slower , the main benefit it is more cheap .
    May 2018
    35
    We mark on anodized aluminum all the time with our mopa laser but the marking area is small and the speed is slow too. https://www.youtube.com/watch?v=6Gfg6lA4LX4
    Aug 2005
    205
    First, I'll say I don't know anything about lasers, but I watched this video recently and it may offer an alternative. There is a link to the company that makes the hardware (in Poland). Good luck with your search.
    https://www.youtube.com/watch?v=23uJlaL0oJM
    Nov 2010
    787
    Quote Originally Posted by MotorMounts View Post
    Engraved signs are so big???
    CNC lasers, constructions, service
    Mar 2015
    178
    Google Tykma Zetalase XLT
    LMT Cobalt XD
    Jan 2015
    I do a lot of anodized tags and signage with 3 basic 30w galvo fiber lasers. One thing I've found is that it's not always time-saving to try fill the whole table with many parts at once. Case in point, I make small ID plates for an auto brake company, and I found that just doing a few at a time ends up taking much less time overall than trying to do as many as the machine will fit. In the amount of time it took to prep the machine to run 20 at once, I was able to have 60 pieces done already running 2 at a time. A 300 part job took about 2/3 the time at 2 up than it would have at 20 up. If you're engraving sheet stock that can be accurately cut around the engraving AFTER engraving, then a large table can speed things up. But if you're engraving individual parts, the initial setup time and the parts-out-parts-in can will kill you.
    Mar 2015
    178
    Interesting. I set up several 50W fiber marking lasers at work including one where we had to do the final mechanical integration in house. Currently looking to add 2 more and one of the requirements given was a larger format marking area to be able to mark more parts in one cycle. So what you’re saying is the time spent fiddling with the setup/ part and fixture alignment to the marking template exceeds the cycle time overhead to load unload individual parts? I’m not doubting you but in our case we can usually bang out a template and fixturing rather quickly so we opt that route. I suppose if you are only doing 60 pcs and the job won’t ever come up again it may well be faster to brute force it. We have standard size aluminum tags so gridding the template is pretty repeatable. What would be intriguing is if something inherent in the galvo or laser was less efficient time wise having to steer across a large area if that makes any sense?
  1. Need 7075 aluminum parts laser cut, polished, and anodized
    By genealogyxie in forum RFQ (Request for Quote)
    Last Post: 12-18-2015, 04:55 AM
  2. Laser Marking Clear Anodized Al
    By petriej in forum Engraving Machines
    Last Post: 10-20-2014, 12:25 AM
  3. Each laser marking machine parts and lifetime warranty
    By mornlaser2014 in forum News Announcements
    Last Post: 06-20-2014, 11:11 AM
  4. Replies: 0
    Last Post: 06-14-2013, 08:53 AM
  5. Small (1 sqr inch) 6061 Alu parts, Hardcoat anodized
    By KevinWilkins in forum Employment Opportunity
    Last Post: 03-11-2010, 06:35 PM
