586,590 active members*
2,189 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Videos > SKD11 Steel CNC Machined Part
    Oct 2020
    17
    Cool SKD11 Steel CNC Machined Part
    110*76*9.5mm SKD11 #CNC #machined #parts with milling, grinding and WEDM-LS process.Titanium plating finishing with tight tolerance 0.005mm.
    Positioning fixtures are used in non-standard automated semi-automatic equipment related to automobiles. Mechanical processing is mainly grinding machine and slow-moving wire cutting processing, the accuracy is within 0.005mm, and the positioning accuracy is high.
    https://www.youtube.com/watch?v=9MrTbxxa-8s
    Oct 2020
    17
    Re: SKD11 Steel CNC Machined Part
