587,035 active members*
3,273 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Finally Took the plunge!!! G0704
Results 1 to 20 of 32
    Mar 2012
    231
    Finally did it, found a real clean slightly used mill, $1500 with a bunch of tooling.
    Prob leave it manual, then convert with stock screws, then swap out for ball screws...
    Re: Finally Took the plunge!!! G0704
    Cool!
    Just go straight for ball screws if you can afford it. It's an easier conversion for a lot of reasons, also lead screws don't really make sense on a CNC machine.
    I ran mine manually for year before converting. Sometimes I wish I still had a manual one. If for nothing more than having a really nice drill press.
    Mar 2012
    231
    Quote Originally Posted by CL_MotoTech View Post
    Cool!
    That's kind of where I'm at, I have a full sized drill press this will be replacing, I have all the electronics from a router I built, so all I really need is to attach everything. Probably belt drive like Flashcut.
    It's sounds like you have a plan! Good luck!
    Mar 2012
    231
    I have had Hoss' plans forever, plan on doing his MAD drawbar mod. Do I need a special drawbar or modify the stock one? Can't find any info on it in the plans.
    CR
    Dec 2011
    29
    Cool!
    I agree, don’t bother with putting steppers (or servos) on lead screws.
    You likely saved a ton of cash on tooling when you bought the mill so you are already up.
    I used a lot from Automation Technologies. GREAT screws, GREAT electronics but CRAP steeper mounts, I mean Crap! They looked like an angry beaver gnawed them out of scrap.
    Hands down I would go to them for the screws and electronics, the smooth stepper ether net board is excellent. But if you can find something like Arizona Videos mounts go for them,
    I always intended on making my own set of mounts but honestly once I got my mill dialed in I haven’t looked back.
    So many great mods, so much information on this little mil but I’d say save up for a complete, proven set of screws and steppers, load up Mach 3, fusion 360 and start making what you want.
    CNC is whole different kettle of fish. I manual mill at work because I have to, it gets basic things done. But on a CNC machine you can make things that impress and solve unique problems.
    BTW. I put a belt drive on mine (Hoss conversation) and kept the quill. I can and do still use as a manual drill press, I left the handle on the Z so I can move the head without powering up the electronics. Best of both I figure.
    Dec 2011
    29
    Quote Originally Posted by ny_racer_xxx View Post
    CR
    The stock drawbar is all you will need, just add the bellville washers. I did it and it works but watch out for “pullout” , if you load up the tool the clamping pressure might not be enough. I had it happen to me with the mod setup, using a 1/2” end mill shoulder milling a deep cut.
    Mar 2012
    231
    Thanks for the reply!!! I did have it off tonight, looks like that cap with the two flats on it that threads into the quill, gets ditched, and just the draw bar with the washers under it...
    I built a router table so I have all the electronics, most came from Automation. I was thinking about something more inline with flash cut to start out with.. I came up with this so far...Click image for larger version.
Name:	XY Full Mount.jpg
    ps When I decide to go ball screw, I'll probably go with the Arizona Video stuff....
    I run Solidworks, it's what I was using at work a few years back, got kind of used to it...
    Nov 2005
    222
    Cool!
    I would second that. I have a converted Sieg X3 which is similar. Good luck on your conversion.
    Mar 2012
    231
    Quote Originally Posted by rcheli View Post
    Ebay vise showed up, 4 inch $60 with shipping, git it in 3 days!!!
    Have to modify the pegs so they fit the slots.
    Mar 2012
    231
    Mounted!!!Click image for larger version.
Name:	Vice Mounted.jpg
    Mar 2012
    231
    Well, just ordered about $200 in parts to build the belt drive, including more than $70 in a tap I'll use once, and a keyway broach and collar I'll use twice!!!
    I'm going with the Optimum ratio's, 50% on the Z axis, and a 80% on the XY, I have some smaller Nema 23's, 270 oz. Optimum uses 2.2Nw, which is about 311 oz/inch, pretty close to get me feet wet..
    Mar 2012
    231
    This is what I have so far...
    Attached Thumbnails Attached Thumbnails 20201126_193534.jpg   20201126_193550.jpg
    Nov 2020
    Hi. I don't know whether I should ask this question here in this thread or not but still...Just wanted to know about the Kreg router table mention at no. 2, here in this article https://top15products.com/tools/best-router-table/
    Is it worth it or not?
    Mar 2012
    231
    Attachment 453792Attachment 453794Attachment 453796
    Made the first motor mount, and threaded the Z Axis gear. I bought a gear with a 1/2" bore, then bored it out in the lathe to the tap drill size, then luckily my 1/2 Procunier fit the M16 tap without a collet, went in like buddah! Nice and true..
    Waiting on some 3/8" aluminum plate to adapt those motor mount to the lathe.
    Looks great man!
    Mar 2012
    231
    Looks great man!
    Thanks getting there in between customer jobs. Damn paying customers always getting in the way!!!
    Mar 2012
    231
    Messed around with the speed controller, was speeding up when loaded down, stalling, etc... Looked over Hoss' video, the compensate surged at full clockwise, seemed better, near full counter. Still acting funny, limit around just past 50%. Turned the High Speed Limit full clockwise, adjusted the compensate, now seems pretty good, steady rpm while making heavy cuts, stalls much less..
    Tried broaching a keyway with a 5/32" parting tool in the lathe, just moving the compound in to remove material. Getting there, but have to dress the tool better... Waiting material for the adapter plates and stand offs...
    Mar 2012
    231
    Dry Fit of the Z Axis, looks pretty good, need to shim the plate up about 5/32"...
    Attachment 454206
    Attachment 454208
    Attachment 454210
    Mar 2012
    231
    Ended up like this, belts align better, I think it looks cleaner, only issue now is holding the lock nut on the spindle because the adapter plate is in the way. I think I have a solution, bore a hole through the side of the plate, drop a pin in there to hold the nut.Attachment 454284Click image for larger version.
  1. FINALLY Starting my G0704, and I'm going to need a 4th axis
    By bogiestl in forum Benchtop Machines
    Last Post: 03-24-2014, 04:22 PM
  2. g0704 and tools all finally here
    By Whizbang in forum Benchtop Machines
    Last Post: 12-15-2012, 10:27 PM
  3. Made the plunge in the G0704 Pool
    By USN in forum Benchtop Machines
    Last Post: 05-04-2012, 11:03 PM
  4. I made the plunge and finally started!
    By RTamer in forum DIY CNC Router Table Machines
    Last Post: 09-02-2011, 03:56 PM
  5. OK, I have finally taken the plunge
    By WJHildreth in forum CNC Wood Router Project Log
    Last Post: 05-26-2006, 11:53 PM
