I have recently been building my CNC router Frame, and am ready to purchase the stepper motors and controller.
I can get 4 nema23 motors for £35. Specs are:
- Rated current 1.2A
- Rotor inertia 0.55kg-cm2
- Output shaft 6.3mm dia x 19mm long
- Holding torque 0.314Nm (3.2kg-cm)
- Detent torque 0.0492Nm (500g-cm).
- 4-connections flying lead 115 mm long
- 1.8 degree Step
- 200 steps
The makers specs are Here
The Model is: 23LM-C210-07
and was hoping to use the controller from HobbyCNC.
My machine is 3 axis and the maximum travel is 1 metre. Would this be a suitable setup, or not??? If it is not suitable could some advise on a suitable motor and controller.
Thanks for the Help Guys.
David
