586,655 active members*
2,000 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > File transfer via Ethernet TCP/IP
View Poll Results: Please advise a settings on both of:
Voters
0. You may not vote on this poll
  • PC
    0 0%
  • Milltronics Cent 7
    0 0%
    Aug 2020
    Lightbulb File transfer via Ethernet TCP/IP
    Hello Friends,
    Currently have a Milltronics CNC Machine, which model is Centurion 7.
    The issue that, I am unable to set a communication via Ethernet TCP/IP protocol (ethernet cable is connected to Machine and the other end is connected to wireless modem). May be I am trying to connect somehow wrongly, I don't know.
    What kind of settings should I do on my PC and on CNC Machine directly, in order to share that folder with CAM files to Machine? Something is going wrong in communication...
    Please advise...
    Apr 2003
    637
    Re: File transfer via Ethernet TCP/IP
    All depends on the PC. Transfer the files to a XP computer then try it. If you are using Widows 10, good luck. If you are using Windows 7, it may work. Search this forum, There have been a few discussions about this topic.
    Sep 2010
    529
    I don't think you can hook up a wireless modem directly to your machine. You hook a PC (and yes, older Windows 7 or XP works best) to the machine and then wireless to that PC from your other PC if you like. The operating systems that Milltronics uses, at least in the older Centurion 5 and 6 machines was DOS, so no wireless directly to the machines control.
    Aug 2009
    1573
    ...this link may or may not help you.
    https://www.cnczone.com/forums/millt...cam-posts.html
    Aug 2009
    1573
    misfired reply
