587,006 active members*
3,239 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > PUMA240 Fanuc 0i-TB Display dead
Results 1 to 5 of 5
    Sep 2006
    222
    Machine PUMA 240MC-03
    Fanuc Oi-TB
    After weekend machinde display stays blank. Machine seems to work OK but display dead.
    Small fuse checked and incoming voltage 24vdc ok.
    LCD/MDI unit A02B-0299-C081#T
    Any idea where problem could be or is it just buy new LCD ?
    Thanks,
    GB
    Feb 2013
    788
    Quote Originally Posted by Green Button View Post
    Fanuc Oi-TB
    Thanks,
    GB
    Recommendation: check cables, connections, and power supply.
    If no issue found, call Fanuc 1-888-fanuc us
    Sep 2006
    222
    Re: PUMA240 Fanuc 0i-TB Display dead
    Thanks, i will check these
    May 2016
    526
    Have you checked where the lcd connects onto the board ?
    Does the machine move without the screen on ?
    Sep 2006
    222
    Machine works just fine and moves ok. It's just bit difficult to drive machine "at night"
    I try to look all connections but could not find anything loose.
    I have to contact Fanuc people to check, they will change LED display.
    Faulty part was propably some card behind display.
  1. fanuc 6m dead
    By riverrat in forum Fanuc
    Last Post: 12-01-2012, 06:17 AM
  2. fanuc 6m dead
    Last Post: 11-27-2012, 11:54 PM
  3. Dead Fanuc 10M ???
    By rjhzxc in forum Fanuc
    Last Post: 08-27-2012, 02:20 AM
  4. Dead Fanuc 0M
    By triumph406 in forum Fanuc
    Last Post: 02-07-2011, 06:44 AM
  5. Fanuc 0 dead screen ... dead control?
    By Noss Machine in forum Fanuc
    Last Post: 01-24-2009, 04:03 PM
