586,570 active members*
3,622 visitors online*
IndustryArena Forum > Hobby Projects > RC Robotics and Autonomous Robots > Universal Robots UR3 Robot experiences
Results 1 to 8 of 8
    Jun 2006
    424
    We bought 2 Universal Robots UR3 robots in late 2016. The Robots were sold to us with pneumatic grippers and they had one purpose in life, to unload tubes from CNC turning centers. We make ~8500 tubes a year, but in 2017 we bought a Doosan TT1800SY and it has an upper parts unloader capable of unloading tubes, so we began to make most of our tubes in the TT1800SY and our UR3's have to date unloaded about 14,000 parts at a cost of about $3.70 per part.
    The other day one of the UR3's broke. It began losing position in a way the control told it to feed hold. We contacted Universal Customer service, and they told us to contact our original distributor rather than just send them the robot in a box for repair.
    We also informed them that the rubber seals are not made of Viton and are thus destroyed by coolant in a few weeks to a few months. The second set we bought appeared to be of much lower quality than the first set supplied with the unit. We also mentioned that ideally the robot should have a automatic re-wind feature after an error, because an unload confirmation is something we derive by sweeping the area the part used to be located in with a part of the gripper, and if the UR3 fails to unload, it stops and at that point and quick recovery is profitable. I don't believe this support should require a $7000 torque force sensor, because torque and force have nothing to do with remembering position through a move. The $26,000 robots do a pretty poor job of unloading the parts, and they require an auto-door which is ~$4500-$9000, and companies like DMG mori will build an upper part unloader like our TT1800SY into a machine for ~$28,000 so that's a high end price for the feature we need.
    The waypoint based programming of the UR3, requires paths which are very time lossy to be programmed to prevent overspeed moves. The upper part unloader of doosan takes about 10 seconds to cycle. The UR3 takes about 40 seconds to cycle including the machine auto-door cycle time.
    UR told us to go to the distributor for repair, and that we should have been using a sleeve on the robot. The stupid concept of the sleeve is that the distributor never sold or explained a sleeve product, and the robot wraps itself up in the sleeve so the sleeve is an engineering problem to have. The robot not being coolant proof is crazy because machine unloading is a major part of what the machines do. We put our other robot on the machine we were working on today and attempted to teach it with a makeshift sleeve and the sleeve was nearly a constant issue with programming the robot. I spent 5 hours programming the robot to do the unload, and while doing the programming I watched the stupid robot make a lot of unplanned moves poorly handling the waypoint to waypoint moves and violating a lot of programmed positions.
    In my opinion the UR robot is not the quality of the lowest quality CNC machine in the shop. I'm really unhappy with customer service that says, "go see someone else for repairs", and doesn't have a Viton seal kit, or a sleeve product with the bearings to support the I believe 6 axis motion of the robot without wrapping up, or a software update to get the machine working better for the stupid simple UNLOAD job we have given it. I think the durability of the product is as poor as its quality.
    In my opinion based on the limited information I have and baseless conjecture, the UR robot is a Chinese robot sold by a Danish company apparently operated by hipsters in the US, or at least that's the best I can tell from my limited interactions with the company.
    I think when you buy the robots too, you somewhat slave yourself to the concept of unloading the parts automatically, in a way that makes human unloads a subconscious second class job, and when the product fails your shop, the robot has damaged your ability to conduct that job with your operators introducing a new problem instead of solving the original issue.
    Jan 2014
    106
    Re: Universal Robots UR3 Robot experiences
    I agree with what you have said. They are cheaper than other brands.
    Did you purchase the UR specifically for the collaborative environment? Or because your company thought it was a cheaper option than the others?
    You can get a 7-12 Kg motoman industrial robot for almost the same price, at least i can. And not hassel with a company trying to break into market.
    Although i have seen many UR robots out there but only for very simple applications and not time sensitive.
    Jun 2006
    424
    Quote Originally Posted by bill4807 View Post
    We didn't want to put guarding around the machine, and we were told the robots would work well in the application. Now we are told that the coolant is a problem, and it doesn't appear that UR robots has a coolant sleeve solution for the robot that doesn't wrap up. It appears their customer service doesn't have a headquarters shop where they can repair robots either because they are not offering a US headquarters based solution but are instead suggesting distributors handle the repairs for them- when in this case the robot was sold by a customer of a distributor so essentially there may not be a customer service party to address the repairs?. The UR robot is seeming like a toy robot advertised to be an industrial robot.
    I think industrial in this industry is a definition that means long term durable, and this product doesn't seem to belong in that category.
    Jan 2014
    106
    Quote Originally Posted by Green0 View Post
    No the product does not belong in that category.
    If you do make a change from the UR you could look into area scanners/an area scanner to protect the robot zone instead of guarding. Depending on how your safety team evaluates it, but their are plenty out ther like that.
    I wonder how is the coolant hitting the robot, Are you flushing the fixture or part as the robot picks it?
    When we do machine tending applications yes some coolant gets to the arm, but not to much unless the part needs to path above the arm and coolant from the part drips down into it.
    Coolant and chips are always the unknown variable for us to manage. Its a pain sometimes.
    Jun 2006
    424
    The Coolant is dripping off the cabinet ceiling because the machine uses high pressure coolant. So there is no way to have a dry cabinet ceiling when the robot goes to pick. There is no flushing or active coolant when the door is open for the robot unload.
    We got a quote for repair today. $13,422 which is 51% of original cost on this UR3- and the repairs don't touch the controller or pendant hardware, so they are working on 50% of the $26000 item for 51% of cost. It really begs the question of why if UR is going to sell a glorified RC car arm, why they don't have a $6500 replacement fee or something like that. The repair department should be solely throwing out arms and re-calibrating controllers to new throw away arms. This repair quoted from a third party to UR [who apparently doesn't have a repair department] is absurd.
    We got our first 2000 unloads for $13 each (paying the robot $78 an hour for worked hours), and if the repaired robot was as good as new, we could expect $6.71 unloads until it breaks again. These numbers say companies would be better off to put a $18 an hour employee with benefits on the machine because we were unloading 6 times an hour, so if total cost of the employee with benefits and taxes is $30/hour, that's a $5 unload. The UR Robot is the answer to ABSOLUTELY NOTHING. The employee could pull chips off the part, air blow the part, inspect the part, rack the part, and potentially do something else value added with the other 8 minutes per part like provide bars to the loaders, inspect other parts, clean- organize.
    Fanuc should be making a marketing video where a Fanuc robot just dismantles a UR robot- just tears it apart and deposits it in a trash can. That's what these numbers and this experience says. It wouldn't even be unprofessional- it would be a public service announcement.
    maybe take the blue caps off and blow off any coolant inside and see if it solve the problem. Not sure how the arm keeps track of position but it couldn't hurt.
    Aug 2022
    I’d say cryptocurrency exchange is not important but necessary https://www.greedyrates.ca/blog/best...s-canada-2017/. It’s an essential part of every crypto process, so you should read some articles about it. Actually, I’d say it’s as necessary as applying crypto pairs trading strategy. I’d highly recommend you try this strategy while trading your cryptocurrency. Actually, according to my experience, this strategy allows you to value your assets without using fiat money. And I think that it’s the main advantage of it. Anyway, the choice is up to you. Hope I’ve helped you. Best wishes.
    Mar 2023
    Shiba Inu is a breed of dog originating in Japan and known for its small size, friendly demeanor, and distinctive appearance. In recent years, the Shiba Inu has also become the namesake of a popular cryptocurrency known as the Shiba Inu coin. This cryptocurrency has gained significant attention due to its playful branding and its relatively low price, attracting many new investors. However, like all cryptocurrencies, the Shiba inu coin is highly speculative and can be subject to significant volatility. It's important for investors to conduct thorough research and to only invest what they can afford to lose when investing in cryptocurrencies like the Shiba Inu coin. Despite the potential risks, the Shiba Inu coin remains a popular and intriguing investment opportunity for many crypto enthusiasts.
  1. Mounting an Universal Robot UR5 on our Haas VM6
    By PieceMaker in forum Haas Mills
    Last Post: 09-23-2017, 10:21 AM
  2. Replies: 0
    Last Post: 08-14-2017, 12:00 AM
  3. Replies: 0
    Last Post: 08-13-2017, 11:56 PM
  4. Industrial robots and robot equipment
    By Prove Koneistus in forum Manufacture Company Listing
    Last Post: 06-10-2014, 07:18 AM
  5. Replies: 0
    Last Post: 07-30-2013, 07:03 AM
