586,850 active members*
2,012 visitors online*
    May 2006
    99
    FANUC-OM ATC Problem
    Hello there,
    I' am having a problem with the ATC arm. The arm is pulling out the tool a little earlier than the pullbar lets the tool loose. Does anyone know which diagnostic/parameter number i need to modify the timing? This is what the Kitamura book says:
    The ATC timer is set by the DIAGNOS DATA.
    The following is its standard setting values and contents.
    DIAGNOS DATA................SETTING VALUE......................CONTENT
    310...............................500............. ..........................For after ATC UP
    305...............................500............. ..........................For after TOOL UNCLAMP
    315...............................500............. ..........................For after ATC DOWN
    Each setting value is 1/1000 sec.
    The values that were set are: 310.......900000
    305.......60000
    315.......3000
    I have changed all from 0 to 9999950. None seem to slower or fasten the movement of ATC-arm or pause. Please need HELP!
    Is there anyone who has a FANUC-OM INSTRUCTION book in PDF format or any other format to mail?
    Thanks again...
    Apr 2005
    3634
    I don't run FANUC, couldn't you just add some dwell time?
  1. Fanuc Oi-TA LCD problem
    By rai in forum Fanuc
    Last Post: 01-31-2012, 01:00 PM
  2. Fanuc 21i-T DNC Problem
    By Stebedeff in forum Fanuc
    Last Post: 07-16-2007, 09:00 PM
  3. Fanuc OT problem
    By Skybrake in forum Fanuc
    Last Post: 02-09-2007, 07:04 AM
  4. Fanuc 6mb G54 problem...
    By kangarabbit in forum Fanuc
    Last Post: 05-08-2006, 08:35 PM
  5. Fanuc 5 problem
    By jevs in forum Fanuc
    Last Post: 02-22-2005, 02:36 AM
