586,728 active members*
2,919 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 2" face mill does this spped and feed seem right? on pcnc 1100
    Aug 2012
    18
    I have a Pcnc1100 S3, I bought a 3 flute 2" face mill to use on some 6061, It looks like I could run about 475rpms at 2ipm feed rate? does that seem about right? I don't know at what depth of cut.
    Mar 2020
    218
    Re: 2" face mill does this spped and feed seem right? on pcnc 1100
    HSS or carbide?
    Fwiw I run my superfly (single carbide insert, roughly 2.6" diameter as currently configured) at 2500rpm. I get decent results from 12ipm at .075 DOC but if I want a really nice finish I come down to 10ipm and do a finish pass at .01-.005" DOC.
    Nov 2012
    591
    For 475 rpm 3 flutes that sounds like a reasonable feed rate.
    For carbide inserts I think you should be able to spin faster, and increase feed rate to match, although it does matter whether you're skimming or hogging.
    Horsepower will limit how deep you can cut, and you get less of that the slower you spin. Then again, as speed and depth go up, torque goes down, so on small spindles, it generally needs some tuning to the specific setup, no matter what.
    475 rpm at 2" diameter is only 250 sfm, which is fine for tool steel in 6061 but you can push much faster with carbide. Try 2000 rpm and feed at 8 ipm, if you're surfacing/skimming, and using carbide inserts.
    What geometry/type is the face mill?
    Mar 2011
    480
    Quote Originally Posted by LSX View Post
    Aluminum I ran max spindle speed with a 2" ripper mill. A good starting point would be max speed at .05 deep 1.8" step over at 30ipm. Flood cool if you can.I was using a solid r8 holder, not TTS
  1. Physical Feed Rate Override knob for PCNC 1100
    By Helder22 in forum Tormach PathPilot™
    Last Post: 09-28-2022, 05:45 AM
  2. Tormach PCNC 1100 CNC Mill Package
    By weh22003 in forum Tormach Personal CNC Mill
    Last Post: 08-25-2017, 08:46 AM
  3. physical Feed Rate Override knob for PCNC 1100
    By Helder22 in forum Tormach Personal CNC Mill
    Last Post: 10-19-2015, 12:41 AM
  4. Tormach 1100 S3 using Tormach 1.5" face mill....
    By dneisler in forum Tormach Personal CNC Mill
    Last Post: 05-06-2015, 04:50 AM
  5. How do you get the spindle to turn on with a PCNC 1100 for "maual" milling?
    By SwampDonkey in forum Tormach Personal CNC Mill
    Last Post: 06-03-2013, 05:43 PM
