586,728 active members*
3,243 visitors online*
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Jul 2011
    39
    Is it normal if I took L298 and connect it only to the power pin 4 and pin 8 GND to the pin 3 is almost equal to the voltage of the voltage source, I smacked 4 new L298 and we all let the voltage on pin 3 when connected to the voltage source 4th pin
    Do you believe that L298 of 4 chips that are just all wrong, all new and never to them is not connected to a stepper motor.
  2. #22
    Jul 2012
    10
    Hello,
    I tried builing a similar board with l298 and l297 xyzsmsch1
    The problem i dont have any bipolar motors, only unipolar with 6 wires.i put the motor to act as a bipolar with 4 wires.
    I use EMC2 as software.The problem is when i try to activate the motor (x axis) nothing happens.I have 4.9 V in pin 10 on l297.
    Can anyone help me?
    Thanks.
    P.S. This website L297-8 - PMinMO.com
    has a similar board schematic, i was wondering it will work with unipolar stepper motors?
  3. #23
    Jul 2011
    39
    Quote Originally Posted by Sekai View Post
    Hello,
    Can anyone help me?
    Thanks.
    Look theat web page Arduino Forum - Paid tutor wanted
  4. #24
    Jul 2012
    10
    Quote Originally Posted by mojalovaa View Post
    Thanks for the reply.
    But i tried that and the motor just heats up and nothing is moving.Perhaps is the 8 diodes i used (FR302, SF54, PR3002).
    Edit: I obs. that i used 1.5k as potentiometer and the 2 resistor 0.82 ohm and 0.27 ohm at 3 W. Does this change something?
Page 2 of 2 12
  1. L298/L297 contoller need help
    By sixpence in forum CNC Machine Related Electronics
    Last Post: 11-21-2013, 03:47 AM
  2. Help pls L297/L298 board problem
    By crazydaddy in forum Open Source Controller Boards
    Last Post: 09-10-2011, 04:44 PM
  3. Troubles with L297/L298
    By ragrillo in forum Open Source Controller Boards
    Last Post: 10-21-2010, 02:10 PM
  4. L297-l298 stepper board design
    By watchman in forum Stepper Motors / Drives
    Last Post: 03-29-2007, 03:00 PM
  5. Clarification on using PWM with L297/L298
    By adroitguy in forum CNC Machine Related Electronics
    Last Post: 01-20-2006, 07:37 AM
