586,308 active members*
3,485 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    Jun 2007
    25
    Question what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    hello i'm new member live in quebec and i have starting to built a cnc
    with the same design at this adress
    http://lafondje.perso.cegetel.net/ch.../CNC%20040.jpg
    or what your recommended?
    p.s.: excuse my english i speack specialy french
    Feb 2004
    1086
    Apex, you can use 1/2" radial ball bearings for ACME 1/2-10. You also want some sort of thrust bearings to keep the screw from moving laterally. Check out my website for a way to do this without machining the ends of the rod, www.cncrouterparts.com. If you are interested, you can order parts and have them sent to me, and I can send a single shipment to you in Canada to avoid high freight costs.
    Ahren
    Sep 2006
    245
    Are you talking about using ball bearings in the grooves of the ACME screw to make a ball screw? The balls would need to ride along both sides of the thread. The balls would have a third contact point on the top surface. Wouldn't this require something to slide as the balls roll?
    The balls roll with contact points at opposite sides in a true ball screw. There are no sliding surfaces.
    Jun 2007
    25
    i want a bearing fit in 2 grooves at same time,
    the bearing turn and forward when the screw turn
    thanks for your info
    Sep 2006
    245
    That sounds like an interesting idea. I still think there will be some sliding surfaces, but there might be less friction than a standard ACME bearing.
  1. Ball screw or Acme lead screws
    By bgolash in forum Polls
    Last Post: 12-26-2020, 12:00 AM
  2. acme or ball screw
    By smarbaga in forum Mechanical Calculations/Engineering Design
    Last Post: 06-11-2010, 04:46 AM
  3. bearing lock nut on ball screw, how to?
    By replicapro in forum Linear and Rotary Motion
    Last Post: 01-11-2006, 02:28 AM
  4. acme screw to ball screw question
    By Billw in forum DIY CNC Router Table Machines
    Last Post: 07-18-2005, 06:10 AM
  5. Need cheap source for acme lead screw parts
    By Hack in forum DIY CNC Router Table Machines
    Last Post: 02-22-2005, 06:10 PM
