587,058 active members*
3,823 visitors online*
Results 1 to 1 of 1
    Jan 2020
    Used Okuma GI20N CNC ID Grinder
    Used Okuma GI20N Grinder Internal, 1999
    More Details: https://www.jspetersmach.com/Used-Ok...-Internal.html
    Swing over Table 19.69"
    Center Height 9.8"
    Grinding Length 7.87"
    Range of Bore 0.20-7.87"
    Max Grinding Taper 20 deg
    Work Weight 330 lbs
    Spindle Nose dia 3.94"
    Workhead Swivel 10 deg
    Equipped With:
    2 Spindles 30,000 & 50,000 RPM
    Okuma OSP700G Control
    9" Chuck
    Rotary Disc Dresser
    Coolant Tank
    Chiller
