586,713 active members*
3,100 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > NUBIE needing some help. toolpath for concave cut in fusion 360
    Jan 2013
    17
    Unhappy NUBIE needing some help. toolpath for concave cut in fusion 360
    First time I have attempted concave milling cut in fusion 360 on DIY cnc mill using mach 3. So far
    no matter what I try toolpath does not generate to my needs for part. Not even sure if this is 2D or 3D toolpath
    candidate. Have been using fusion 360 for a few months but still learning. Any help greatly appreciated
    for toolpath type and geometry. Attached drawing depicts concave area to be cut. If possible would be great
    to see the toolpath and geometry settings.
    Attachment 449746
    Mar 2008
    683
    Re: NUBIE needing some help. toolpath for concave cut in fusion 360
    There are several ways. If it were my part....
    First I would create a sketch defined stock contour which included the non concaved side fillets.
    Then, I would use a 3D adaptive clearing operations all the way to the bottom using the "flat area detection" option.
    Then... I would use 2D contour finishing passes to clean up the cuts driving the dept of the first cut to the flat surface of the feature at the bottom.
    Jun 2008
    1838
    Quote Originally Posted by kansaswoodrat View Post
    If you only want to machine down to the shelf level then that is easy enough, do what warrenb suggests and set the botton height to the top surface of the shelf.
    If you want to go full depth then the bad news is that it can`t be done, to get the full shape with the sharp corners it would need to be done on a "wire" cutting machine.
    Zip file of Fusion f3d file attached.
    Hope that "helps"
    Stay Safe
    Regards
    Rob
    Jan 2013
    17
    thanks...here is what i did
    Attachment 449908Attachment 449910
  1. Weird rotary movement with fusion wrapped toolpath
    By ubergeekseven in forum Avid CNC
    Last Post: 09-24-2019, 04:12 PM
  2. Toolpath precision issues from fusion 360
    By GeoffreyP in forum Autodesk CAM
    Last Post: 05-29-2019, 08:18 PM
  3. CNC Nubie
    By rpais85 in forum Mentors & Apprentice Locator
    Last Post: 02-18-2011, 04:49 PM
  4. another nubie needs help!!!
    By J.Ballantyne in forum Canadian Club House
    Last Post: 04-20-2010, 10:33 PM
  5. Nubie needs help
    By SPEEDRE in forum CNC Machine Related Electronics
    Last Post: 06-08-2005, 09:28 PM
