586,369 active members*
3,249 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > BAD V error on a Partner 6 Centurion 5 controller
Results 1 to 15 of 15
    Jul 2007
    6
    Hi guys. New to the forum and the CNC machining world. Purchased a Partner 6 with a Cent 5 controller. Got the machine up and running and when the last set of checks on the screen you see the error message "BAD V" and then the normal screen appears for a second and then I get an error message. Says hit ESC or RESET to continue. Doing that does nothing.
    Now I have played with the connection to the control pannel while holding down the reset key and I can at times get the machine to come up to the normal menu and get control of the machine. Lights for the buttons are no longer lit up but it works. Seems when the lights are lit on the pannel, no luck.
    Anyone ever run into this? Know what a BAD V error is?
    Any help would be greatly appreciated.
    Kevin
    Aug 2005
    1622
    Just a thought, but check your 24-volt power supply or a short in a bulb pulling it low on startup. Hard telling but the logic might be seeing it before the 24volt supply comes up. It could be a bad capacitor, ground and a myriad of other issues with power. If the button lights do not function, check the keyboard encoder board inside the monitor housing. There are (2) +24volt lines and (2) DC grounds coming from the supply to this board. Not that they are independent supplies, just that the problem could follow one leg or the other. You should also find 5 and 12volts going to this keyboard encoding circuit on connector J2.
    Where the V error is detected is a mystery. Nothing in my info that shows that particular error message. Is there a error number preceding that message?
    Depending on the age of this machine, but if it has a simdrive for a hard drive, the on board lithium battery may be going/fading. Then there is the CMOS battery on the MB. Although, I'd expect a low bat error rather than bad V error.
    DC
    Jul 2007
    6
    still looking into this
    Thank you for the reply. Yes we check the 24v and it appeared to be good. When the machine is coming up, it says initilizing acro loops, then it says initilizing front pannel and then the Bad V flashes just for a second after that. Menu comes up normal for a second then I get an A 450 ESTOP condition and it says to "reset drives or press ESC to clear message." Pressing ESC does nothnig and I have only had some sporadic luck with holding the reset button down and disconnecting the lead from the pc to the monitor housing.
    This machine does have a sim drive and boots from it. I could not find a typical PC battery in the case, Im under the assumption that it must be soldered directly to the MB somewhere correct?
    Thanks for the reply and help,
    Kevin
    Aug 2005
    1622
    Since that is happening prior to the shell screen, more or less still in the boot mode, it may be associated with the video resolution setting in the parameters or CMOS. Typically 640x350.
    The machine will boot up to the 450 estop error as a normal process because the drives have not been started yet. Pressing the reset energizes the servo drives via an estop holding relay, again part of the normal startup procedure. The same thing will show up if you hit the estop and the holding relay drops out the drives. I can guarantee you, escape will never take it out of an E-Stop condition.....Heheh!
    If need be, you could swap one of the other rarely used switches with the reset switch to see if that takes care of the intermittent there.
    Newark has these switches, lenses and lamps. Not that one of yours is bad, but eventually, you will need them. The failure rate on the cycle start key is around 2-4 years of daily use with ham handed operators. Much less with the reset key, but it may have already been swapped around previously compromised.
    23F4332
    The simdrive battery may be a square block lithium type or a lithium/nicad round type. Seems I have seen both soldered near bottom of the sim board. The nicad on the PC motherboard is about .5-.625 round and maybe .75 long. Lower left corner of the MB. Again these are going to fail eventually. It is not a matter of IF....so either backup data often or store it on another PC.
    DC
    Mar 2005
    171
    I agree with One of Many, I had a similar problem, checked voltages. power supply, e-stop swithces etc. and it turned out to be the cycle start button.
    I would suppose it could be any of the buttons. Interesting that your machine
    won't work when the buttons light up, mine was just the opposite.
    Ben
    COBRO Mfg.
    Oct 2006
    179
    A "BAD V" error upon boot up could be a few things. The parameter "serial keyboard" may be set to yes. Make sure it is set to no. This is a power parameter. Secondly, The keyboard encoder card is bad. Thirdly, you may be missing the 12VDC at the front panel. Many times replacing the keyboard encoder card solves the problem.
    Jul 2007
    6
    Updates....
    He guys.... did a backup of the parameters and got a listing of files on the floppy.
    Power.dat and Pfile.dat were two that I opened up in wordpad. I am assuming Pfile.dat is the parameters file? When I opened it, it did not have much that I could read in it. Was a bunch of squares and odd ascii characters.
    The power.dat file is as follows. Could not see anything abt screen resolution or anything.
    0000; Changes here take effect on Power-Up.
    0064XInitial Units are ,G20 English,G21 Metric
    0065bNumber of Axes
    0704 Power-On FeedRate
    0068bSpindle Axis
    0070B100% Rapid in Run (No Override)
    0071B100% Rapid in Dry-run (No Override)
    0072BSpindle on in Dry-run
    0073XTool Tables by,Radius,Diameter
    0075BLoad TEXT Cycles
    0076BDon't Load Canned Cycles
    0000; ******** Tool Changer Info ********
    0044XMachine is Partner,Other,PI,PII,PIII,PIV,PV,PVI,PVII,PVIII,PI X
    0069XATC Type is,PVII,Manual/Avanti,P1 6/12,3?,4?,5?,6?,7?,PVIII/PIX
    1504 ATC tool (pocket) count
    1599 Spindle orient delay (ms)
    0130TM6 (Tool Change) Macro
    0084XPartner I ATC is,Plunger,Geneva Two-Step,Geneva One-Step
    0200bPI/PVI ATC cw Coast
    0201bPI/PVI ATC cw Brake
    0202bPI/PVI ATC ccw Coast
    0203bPI/PVI ATC ccw Brake
    0000; *** For PVII Turret Only
    1501 Turret pulses per pocket
    1502 Turret home offset
    1522 Turret backlash pulses
    1506 Turret position velocity
    1510 Turret home (0=inhibit)
    1511 Turret vel toward home
    1512 Turret vel away from home
    1513 Turret vel toward marker
    1515 Turret jog velocity
    0000; *** Custom M and G code Tables ***
    0110bCustom Gcode O9010
    0111bCustom Gcode O9011
    0112bCustom Gcode O9012
    0113bCustom Gcode O9013
    0114bCustom Gcode O9014
    0115bCustom Gcode O9015
    0116bCustom Gcode O9016
    0117bCustom Gcode O9017
    0118bCustom Gcode O9018
    0119bCustom Gcode O9019
    0120bCustom Mcode O9020
    0121bCustom Mcode O9021
    0122bCustom Mcode O9022
    0123bCustom Mcode O9023
    0124bCustom Mcode O9024
    0125bCustom Mcode O9025
    0126bCustom Mcode O9026
    0127bCustom Mcode O9027
    0128bCustom Mcode O9028
    0129bCustom Mcode O9029
    0000bParameter File Version
    0058BUse Smaller Soft-Keys
    Could my parameters be corrupt? How do I go about fixing?
    Figured I should start here first before checking voltages and switches. Not sure if this is a problem but I would think I should be able to read all of these files.
    Thanks for the help,
    Kevin
    Jul 2007
    6
    Updates....
    0065bNumber of Axes
    0068bSpindle Axis
    Kevin
    Oct 2006
    179
    Corrupt parameters has nothing to do with the Bad V error upon boot up. Please refer to an earlier thread that I have posted as to what the problem may be.
    Jan 2007
    333
    If it IS the keyboard encoder board:
    There is a 5 volt regulator on a LARGE heatsink on the keyboard encoder board that is almost always the failure.
    The cards are several hundred dollars so I'd find somebody with a soldering iron and replace the $1.50 part first.
    www.nteinc.com can cross-reference the number if DigiKey doesn't have the actual part.
    Jul 2007
    6
    parameters....
    jpawelk
    You referenced a serial keyboard setting in the parameters
    A "BAD V" error upon boot up could be a few things. The parameter "serial keyboard" may be set to yes. Make sure it is set to no. This is a power parameter."
    That statement led me to look at the parameters. Where (what file name) would I find the serial keyboard setting you referenced? I do not see it in the file I cut and pasted here.
    I have the pannel out of the machine now. Starting to inspect things closer.
    Thanks for the replys so far
    Kevin
    Jan 2007
    333
    Kev13,
    The control uses several files to compile the parameter screen you see when you are in access level three. What you posted was ONE of the templates used in this compiling and the hex codes at the beginning of each line are the addresses in another file that contain the values for that particular parameter. You can't really decipher or change anything (and you SHOULDN'T) in any of these files unless you do it through the control.
    This is why you should ALREADY have backed up your parameters when your machine was running good.
    If you have the backed up parameters, there's a way to get to the DOS screen in the control and copy them back in, if your machine doesn't have an electronic problem.
    Matter of fact, a good diagnostic procedure to see if the encoder board is working would be to boot to DOS before the CNC software starts (press any key during the countdown), this would tell you if the control is even "seeing" the keyboard.
    Aug 2005
    1622
    If I recall......JPawelk is an insider....following his direction will lead you to the offending condition.
    To access the parameters section you need to go into UTIL-PARMS-SETUP. This will bring up the VALIDATION CODE: Type in PROTO3 then at ACCESS LEVEL: type in 3. This will allow you to look at and alter the parameters in different sections via the control. Attempting to edit any of this in DOS will hose up the works for sure.
    The machines are usually shipped with a print out of the parameters and a backup disk. Without that, you are at the mercy of the info you have on hand in the manuals and the generous minded people here to offer assistance. If need be, I can email some of that next week.
    There are also some user parameters in UTIL-PARMS-CTRL that do not need a validation code to view, but may be required for changes.
    Write down the existing values and menu locations before you make any changes to them.
    If the parameters were corrupt, I doubt the machine would even make it to the main menu. It would crash before that point during boot.
    DC
    Dec 2008
    30
    I think I bought this guys cnc, its a partner 4(iv) with centurion 5(V) having the same problems still. any ideas?? ive got the book coming from milltronis this week. please let me know!
    Aug 2005
    1622
    Quote Originally Posted by varga View Post
    If you must resort to board level repairs and have little knowledge, it would best serve you to spend the money and have Milltronics confirm the keyboard encoder is in fact bad or further issues with the acroloop controller. A local tech could still save you headaches and/or further complications with too many hands "trying" to correct the problems.
    Once you have the books, you may be able to check basic connections to the supply lines and switch contact continuity, but you will not get board level circuitry schematics. Troubleshooting past the wiring takes knowledge of the inner workings or spare parts to swap out.
    I've seen where Milltronics does not put wire numbers on everything, so that makes it tougher, but troubleshooting competency is essential in unfamiliar territory. Know when to give in and let a qualified tech handle it in short order. Milltronics Technical Support is pretty good, assuming you have a technical apptitude and follow their lead, ask the right questions and convey reliable information requested to the conditions at hand.
    I've seen the results of good intentions gone bad. Never pretty at that point.
    DC
  1. partner 0-5 centurion 5(homing problem)
    By irtaza in forum Milltronics
    Last Post: 09-27-2022, 10:22 PM
  2. Milltronics Partner ? Centurion V Servo Questions
    By sbalder in forum Milltronics
    Last Post: 02-07-2008, 04:35 PM
  3. Centurion 5 vs. Centurion 6 and validation codes
    By Turbo VW in forum Milltronics
    Last Post: 02-11-2007, 09:35 PM
  4. Partner centurion 1 control
    By jas6142 in forum Milltronics
    Last Post: 12-04-2006, 05:49 PM
  5. Need a G320 error/reset controller
    By kevincnc in forum Gecko Drives
    Last Post: 04-22-2005, 02:14 AM
