dual ballscrew
would there be any good reason to use a dual ballscrew setup on a metal mill except for the fact that they are available and will most likely rustaway for a long time if i don´t.
the advantages i figured would be : better load dividing resulting in hopefully "less wear and smoother operation cause the leverage effect is neutralized though i could mount the screw in the middle its not perferred.
maybe i could even squeeze out the last microns of backlash if i preload one to pull on the load and the other to push.(i hope that makes sense)
And most of all i got 20mm lead per turn and a 15mm dia. and as my Z might get quite heavy (50kg) i also want to be sure the screws can cope.Hence the lesser wear they will be put to the test in the setup i'm planning for and a screw slipping or binding while idle should be ruled out with 2screws.
but all i want to know for now is if the combo of 20mm lead on 15dia. ballscrew and a 50kg Z-axis is healthy.
By the way when powerfull motors are used i guess one stepper/servo should be enough if a belt and pulley's are used to drive both leadscrews solving the synchronizing problems you get with dualdriving single axis'.
I hope some of the illuminated could chime in on this and we'll burry the dualghost forever.
THX in ADVANCE.
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
