586,666 active members*
3,564 visitors online*
Results 1 to 10 of 10
    Jun 2020
    41
    Setting work offsets
    How do I offset different sized work pieces and have tool automatically adjust ZTool height(s)?
    Hopefully this is a simple to answer and stupid question.
    Few months ago, I got an MB16 with SLC CNC 6.107 for home shop.
    I started buying up NMTB30 holders so I didn't have to change and reset Z-Height every time I changed a cutting tool.
    Now I'm ready to touch off and store all my different cutters and I know where in machine I have tool library.
    The question is, how do I tell the tool where the zero is for the work piece?
    I see where in the Jog (F2) or HDW (F3) menus I can zero X & Y by using F5 & F6 (G54-X & G54-Y), but the only thing for the Z is a an F7 (ZTool).
    Problem with that, is that it only changes Z-Height for that one tool, and the rest of the tools are unaffected.
    Clearly, the tool is smart enough to know that if i have 1 tools in the library and say each tool is exactly 1" longer then the previous, when I touch off on a part with tool 5 for example, the other 9 tool heights should also be adjusted. Am I wrong?
    Like I said, this is a home shop machine, but lets say I wanted to make 10 gizmos and each required 3 tool changes. No matter how careful I could try, each workpiece will be slightly off.
    I know I can use a jig, base holder, etc. For sake of argument lets say that each piece is different.
    Jun 2020
    41
    Re: Setting work offsets
    Apr 2003
    637
    There is a parameter that will turn on the G54-Z on your screen. I'm not sure where it is or why this is even turned off, It was off on my machine. I had Milltronics walk me through it after I found out this was available. Give them a call.
    Jun 2020
    41
    I called them yesterday. Walked thru the menus but couldn't find the setting.
    The TS is escalating it to next level but told me it might not be possible.
    Quote Originally Posted by moldcore View Post
    Apr 2003
    637
    It may be because your machine doesn't have a tool changer? I'm surprised they didn't tell you why.
    Jun 2020
    41
    The tech I spoke to was very pleasant and tried to help.
    We went into Lev.3 settings and found the area where it 'should have been'.
    He told me the line should be right after (I can't remember now), but that option wasn't there.
    Tech told me he was more of a hardware guy but was going to send an email to the software dude.
    Oct 2017
    39
    In MDI try:
    PB489=255
    Jun 2020
    41
    Quote Originally Posted by stagen View Post
    In MDI try:
    PB489=255
    I did that. What am I looking for?
    I typed that under the F9(Misc).
    I pressed F1 (Store) and Cycle Start
    It took me theo the Display window (normally F6), but no changes to Jog nor HDW that I can see.
    Oct 2017
    39
    On my control setting that parameter byte turns on/off the G54-Z tab in HDW.
    It’s possible that wasn’t an option until the latter software versions (mine is x.305) or possibly not available on the SLS control.
    Jun 2020
    41
    Got it. I wish mine did that. Instead, I saw no change at all.
  1. Hitachi Seiki Horzontal Mill 1997 Setting Work Offsets
    By dserafinchan in forum Hitachi Seikis
    Last Post: 04-24-2017, 03:46 PM
  2. Rapid Turn: Setting work and tool offsets (again!)
    By Fortune7 in forum Tormach Personal CNC Mill
    Last Post: 03-25-2017, 07:12 AM
  3. Setting work offsets on my cnc lathe.
    By drumsticksplint in forum Fanuc
    Last Post: 06-22-2015, 04:51 AM
  4. Setting Tool and Work Offsets
    By Donkey Hotey in forum Haas Lathes
    Last Post: 06-11-2015, 06:40 AM
  5. Setting Work & Tool offsets
    By Shizzlemah in forum Fadal
    Last Post: 04-16-2005, 06:04 PM
