586,500 active members*
1,860 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > Inside circle longer than 360
    Sep 2009
    88
    Hi
    I am doing a lot of inside cutting of circles in Dibond, and because the bit slows down then stops at 360 degree when finishing the circle, there is a lot of material left hanging at the end as higher rpm with close to zero feed rate mets the plastic.
    Is there a way to go longer than 360 so I can clean this?
    Marius
    Mar 2021
    Re: Inside circle longer than 360
    We have found that the best feed rate for a STEPCRAFT 2 series CNC machine using a STEPCRAFT HF-500 Spindle is 30 mm/sec and using a KRESS 800W or MM-1000 Spindles, we found the best feed rate to be 38 mm/sec. A good rule of thumb would be to set the feed rate on the lower end and then you can always increase the speed using the F-SET setting in UCCNC while the job is running. If you determine that you are getting the best results with an F-SET of 120% then you can simply multiply the current feed rate x 120% and make that the new feed rate for that tool. Then the next time you run a job, leave F-SET to 100%. Of course, on the Kress or MM-1000 you can simply make RPM adjustments by turning the speed control knob while the job is running.
  1. Replies: 0
    Last Post: 02-16-2019, 11:34 AM
  2. Cut2D Drawing Slots Inside a Circle
    By ALWAYSPDG in forum Cut2D / Cut3D
    Last Post: 02-28-2018, 06:46 PM
  3. write gcode for circle with 4 small circle inside it
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 12-13-2010, 05:24 PM
  4. TCC crash during pocket milling, polyline inside circle
    By StephanWenger in forum Uncategorised CAM Discussion
    Last Post: 12-02-2010, 03:36 PM
  5. inside circle cutting problem
    By glenthemann in forum G-Code Programing
    Last Post: 12-08-2009, 11:00 PM
