Originally Posted by
mountaindew
I use an ets combined with the post provided for SprutCAM. It generates the g code for all the tool change and tool height setting using the ets. I load a program and set a tool that I can touch off with easy like 45 chamfer mill. I use offsets page to measure that tool with ets. then I move it to work piece and touch off z height with that tool and also set x,y 0. then I run program. It moves over ets and prompts for tool change. change tool hit run it measures tool. hit run again and it moves to work and starts. when finished it goes back to ets and prompts for next tool. repeat until done. Super simple for me. a copy of some g code example might explain it better. it is different then my mill.
If you dont have ets then you are going to do a lot of start, stop I guess. PP does the run from here real well but not clear whats going on with your tool numbers.
