586,753 active members*
7,378 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > Syil X3 CNC No movement from steppers or Spindle
    Hello,
    I just bought a Syil X3 CNC from an estate sale. It looked like it was used until it the owner passed away. I can get the computer on, mach3 loaded with the Syil X3 config, and jogging within mach3. I checked continuity between the DB25 connector, all good. When I power the X3 on I see a green light for the spindle. When I try to turn on (start, speed up, etc.) it just beeps. I press the estop and the spindle speed lcd goes out, and comes back when I reset the estop. When the spindle speed lcd turns on, it says 0080. I press start but it never turns on, and I cannot increase or decrease the speed.
    My other problem is with the steppers. When the power is on I can barely turn the ballscrews, so it seems the steppers are getting some power. I tool the back panel off and saw a red led on each of the stepper drivers. I have checked the estop operation and they seem to be functions ok on the switch side. I have attached some pictures. Does anyone have the datasheet for the Syil 2 phase stepper driver?
    Any thoughts?
    Attached Thumbnails Attached Thumbnails IMG_20200828_152446.jpg   IMG_20200828_152449.jpg   IMG_20200828_152455.jpg   IMG_20200828_163408.jpg
    Jun 2007
    3757
    Cool Re: Syil X3 CNC No movement from steppers or Spindle
    Try these files for driver and rest of machine.
    Might be rubbish on spindle sensor magnet ring.
    Use adhesive tape to clear whiskers.
    Try not to remove sensors, else phasing might be screwed up.
    Your mach3 estop setup might be wrong.
    I need to attach files using computer.
    Please wait. Now I know why it was too hard on android phone.
  1. No movement from the steppers
    By neric in forum Stepper Motors / Drives
    Last Post: 07-20-2010, 12:59 PM
  2. Replies: 6
    Last Post: 05-13-2010, 12:52 PM
  3. Can Not get any movement from steppers.
    By millman52 in forum Machines running Mach Software
    Last Post: 06-01-2009, 12:23 PM
  4. Jerky Movement - Syil X3 Mach 3
    By Megaplow in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-09-2008, 04:10 PM
  5. No Movement of steppers help please
    By rally.sport in forum Machines running Mach Software
    Last Post: 12-22-2006, 04:05 PM
