586,555 active members*
3,445 visitors online*
    Aug 2020
    ball screw replace for Chinese cnc 6040z
    Does anybody know the dimensions for X axle ballscrew cnc 6040z?
    As i understand it is sfu1605, however it's length is 760mm, i can not find any sfu1605 with that length.
    Nov 2012
    1267
    Re: ball screw replace for Chinese cnc 6040z
    Some sellers will cut the ballscrew and machine the ends to your specification. Or you could buy a longer ballscrew and find a local machinist to cut it.
    P. S. "6040z" is a pretty generic term, so measurements from someone else's machine may or may not be correct for yours.
    Sep 2009
    99
    @sashaKR
    You should pull out the screw and make the drawing- the way ball screws are supplied are as plain screws with a ball nut based on your selection. We normally specify the end dimensions which the ball screw supplier then machines and grinds and then gives to us. (I've purchased at least 20 ball screws till date)
    Best of luck!
    Jaideep
    Aug 2020
    Thank you for your replies.
    I understand that ball screw can be manufactured almost any dimension, however i was hoped that for standard cnc, standard ball screw should be enough. There are so many parameters, therefore i don't want to risk and put an order with my measurements. I've seen a lot of standard sfu1605, sfu1610 - so i hoped there should be standard for my cnc as well
    Nov 2012
    1267
    Have some faith in yourself. Measure the ballscrew the best you can and compare it to the screws available for sale. Maybe you will find a suitable ready-made one. Does not need to be 0.001mm accurate; you will adjust it anyway with shims, washers, spacers and such.
    Jun 2013
    443
    And buy a ballscrew already machined. Well, in New Zealand, the people who can machine ballscrews just quoted me NZ$250 for one. Yep.
    Sent from my SM-N970F using Tapatalk
  1. Ball Screw Lifespan - Chinese cheapo's
    By Iceturf in forum Linear and Rotary Motion
    Last Post: 09-27-2016, 09:17 PM
  2. Chinese ball nuts & screw on Ebay
    By SSN Vet in forum Benchtop Machines
    Last Post: 01-28-2015, 10:53 PM
  3. Chinese ball screw - dismantling
    By superagurk in forum DIY CNC Router Table Machines
    Last Post: 09-22-2012, 04:27 PM
  4. anotehr possible way to replace the ball screw concept
    By morphious69 in forum Linear and Rotary Motion
    Last Post: 03-26-2010, 04:48 AM
  5. ball screw rebuild or replace Roboform 400
    By jetski in forum EDM Discussion General Topics
    Last Post: 08-07-2009, 02:33 PM
