586,655 active members*
3,051 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > MULTICAM PUMP VALVE QUESTION FOR SETTING UP ZONES
    Jun 2020
    Post MULTICAM PUMP VALVE QUESTION FOR SETTING UP ZONES
    Good morning all, we have a MG series MULTICAM CNC and with it we are installing the MULTICAM TV425 Vacuum pump. This pump is rated for 15 Hg. and 700CFM. We currently have one main trunk that splits into our 14 "zones" without the control of turning any of them off individually. We are going to re-plumb which brings us to our question. Can I use regular pvc ball valves or is this pump too powerful for that? We plan to have our trunk split into 5 lines with valves that will then return to the zones under our CNC. Not sure if it helps but out CNC is Multicam: MG205NB42893.
    Has anyone here plumbed their cnc for zones? Any tips? Any recommendations?
    Dec 2013
    5717
    Re: MULTICAM PUMP VALVE QUESTION FOR SETTING UP ZONES
    PVC valves will work fine, I have used them to 28 in/hg. But they are a bit stiff to turn. I like 1'' brass ball valves, a bit more user friendly and not much difference in cost.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2012
    1266
    Yes, regular ball water valves work fine for vacuum. I use the same type Jim suggested, 1" brass valves.
