586,508 active members*
3,282 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > 3D Toolpath wrong depth
Results 1 to 10 of 10
    Apr 2020
    6
    STL from Solidworks imported into Aspire 8.5 or 9.5. One side job - internal surface of a funnel type object. 3D toolpaths does not go deep enough no matter what I set as boundary. VisualCAM does not have this problem. See:
    Apr 2020
    6
    Re: 3D Toolpath wrong depth
    Additional picture of machined detail - 3D toolpath does not go as deep as material (20mm).
    Apr 2004
    5741
    Did you perhaps call out a tool that's not long enough to get to the bottom of the hole? Or define your tool holder diameter as too wide to fit down there?
    Andrew Werby
    Website
    Apr 2020
    6
    I've called standard tool. Where is tool length - I don't see in edit window.
    1230
    Quote Originally Posted by jzagaja View Post
    Have you checked out the tool definition in the tool library?
    Apr 2005
    304
    @routalot:
    There is no info on tool length in tool library.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    1230
    Quote Originally Posted by ZASto View Post
    @routalot:
    Then we may have identified the problem.Could you post a screenshot of the tool definition from the tool library?
    Apr 2020
    6
    Are you Aspire user if you ask this? I identified problem - untick "Discard data below zero plane" when importing STL.
    1230
    I have helped out a friend who bought Vcarve,which is similar,and thought there was a fair chance that the tool modelled had a length that would have had the collet nut hitting the surface.I'm glad you found the correct option box to tick for the program to be successful.Did you import the STL because of the slightly offbeat way Vectric deals with CAD?
    Apr 2020
    6
    I design in Solidworks and import to Vectric because it has postprocessor for Vision v.1 controller from 90s. Import is not as good as in slicers for 3D printers.
  1. Toolpath posts wrong
    By jgarner77 in forum Alphacam
    Last Post: 12-09-2014, 11:23 PM
  2. What am I doing wrong here with 4th rotary toolpath!
    By blakemachine in forum Mastercam
    Last Post: 06-19-2012, 11:33 AM
  3. Drilling depth is wrong detected
    By Geo in forum UG NX
    Last Post: 02-03-2010, 10:10 AM
  4. Replies: 10
    Last Post: 03-08-2009, 03:03 AM
  5. Incremental depth milling for 3D toolpath? (V21)
    By speedofsound in forum BobCad-Cam
    Last Post: 10-18-2008, 04:15 AM
