586,655 active members*
3,616 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Autodesk Post Processors > Does anyone have a Laser and Mill post processor for Fusion 360 and mach4 ess
    Aug 2015
    13
    Question Does anyone have a Laser and Mill post processor for Fusion 360 and mach4 ess
    i have a CNC using mach4 and a warp9 ess and i have added a diode laser to it. i have made everything work but right now i have to manually modify the gcode to add in the laser gcode.
    i was wondering if anyone had a post processor for fusion 360 that is capable of outputting the warp9 ess gcode for the laser?
    these guys have one for vetric vcarve and it works great: https://jtechphotonics.com/?p=3851
    thanks
    Raptor
    Jun 2008
    1838
    Re: Does anyone have a Laser and Mill post processor for Fusion 360 and mach4 ess
    Attached is a Fusion PP for Mach from Artsoft, there are many Laser/Plasma/Waterjet Post Processors in the HSM/Fusion 360 Post Processor Library which can be found here :-
    https://cam.autodesk.com/hsmposts?
    Just type in Mach Laser in the search box and a list of them will open, take your pick
    Regards
    Rob
    Attached Files Attached Files
    I've got the same problem. it just won't work with mach 4. and I don't know how to edit the CPS file to make it work, there's no line in the code regarding laser or anything similar. I wonder if using a mach 3 plasma profile would work to output regular router code and manage to work with laser cutting paths?
  1. Fusion 360 post processor
    By mirocha in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-04-2020, 08:32 AM
  2. A working post processor from Fusion 360 to .mmg?
    By KannaKraft in forum Autodesk CAM
    Last Post: 11-01-2019, 10:54 PM
  3. Fusion 360 RS274D post processor
    Last Post: 01-10-2018, 11:10 PM
  4. Fusion 360 Post Processor
    By brianbonedoc in forum Smithy
    Last Post: 03-10-2017, 05:55 AM
  5. fusion 360 post processor
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 03-20-2016, 08:20 PM
