586,915 active members*
2,483 visitors online*
Results 1 to 20 of 28
    Feb 2004
    77
    Maximum Voltage for L298 IC ?
    I constructed a stepper power card using L287 and L298. I used a 12V computer power supply and a big capacitor. It works well.
    Today I tried a 27V AC transformator + rectifier + big capacitor. I measured 35V DC at unloaded output.
    For a short time I connected this unregulated 35V DC power supply to my stepper control card. I checked this combination at high speeds. My steppers worked very well.
    I want to ask will it couse a problem at L298 using unregulated 35V DC power supply?
    Gunol Camlibel
    [email protected]
    http://www.rc-tuning.com
    Jan 2004
    122
    Feb 2004
    77
    Thank you for your support
    I downloaded and readed datasheets at design stage. however I think that 50V is for regulated DC power supplies.
    I wonder if is it valid for my unregulated but rectified power supply.
    Gunol Camlibel
    [email protected]
    Apr 2004
    678
    Your supply will not exceed 35V even when unregulated assuming your mains voltage does not fluctuate. What it will do is to drop voltage with increased load. This hurts your performance, not your electronics. I also assume you're not feeding braking power back into the supply. But most regulated supplies will not help in this case either. They will just stop supplying power, not shunting down what your drive feeds back. If this is a problem, use a bigger capacitor to store the energy.
    Feb 2004
    77
    I used 13000uF 40VDC capacitors for test.
    I connected them alone and two of them connected parallel. Both tests resulted with the same good performance.
    I will use one capacitor + one transformator and rectifier for each axis. Becouse high capacity transformators are very big. therefore I will use three of small transformators for each three axis.
    Gunol Camlibel
    [email protected]
    Mar 2004
    190
    Gunol, could you post some schematics, or better, artwork for the pcb? I think can be a useful board for the CNC OpenSource DIY desing we are involved..
    Thanks in advance
    Fer
    Feb 2004
    77
    There is a shematic at L298's datasheets 8th page. I used that shematic. You can download it from ST or I can send to you via mail.
    I will try to attach it as gif file below
    Gunol Camlibel
    [email protected]
    Feb 2004
    77
    and the same shematic also available at L297's datasheets 1st page.
    also it is here below:
    Gunol Camlibel
    [email protected]
    Mar 2004
    190
    About these schematics (thanks Gunol) I wonder about the /reset and enable signals.. what are they used for? I can imagine the fucntion, but how they apply to 'real world' designs?
    Fer
    Mar 2004
    41
    having designed a system using these chips recently i can say that the only appliction for those signals would be for tying to the ground or the 5v rails. one interesting application note is on parralleing the l298. they can be used for much higher currents in that application. it is also possible to create a discrete bridge to drive larger motors.
    Feb 2004
    77
    I can send datasheets of L297 and 298 who send me an e mail.
    Reset: avtive low (0v) resets the chip initial position ABCD=0101
    therefore you must give +5v to this pin
    Enable: Like an on off switch. therefore you shoul give +5v to this pin.
    to IT POULE:
    can you describe how to paralleling 298's?
    Gunol Camlibel
    [email protected]
    Mar 2004
    41
    the instructions are on page 7 of the l298 data sheet but basicaly you tie the #1 and
    #3 input together then the #2 and #4 these connect to the phase one and phase two out puts for the first 298 and the phase 3 and phase four for the second 298. the out puts are connected in the same manner. tie the sense inputs togeter and use them normally ie sense 1 for the first 298 and sense 2 for the second.
    you may need to reduce the resistance of the sense resistors but i have not gotten that far yet. the enables are handled the same way as the sense inputs.
    Feb 2004
    77
    Thank you,
    I will check and test this. and I will post the result here. thank you
    Gunol Camlibel
    [email protected]
    Mar 2004
    41
    no problem, actually it will be good to get a second opinion. my design is not quite ready i still need a few small parts and iam also considering a dicrete driver
    Oct 2003
    36
    Here is apic of the 3-axis board I built with the L297 and L298N chips. The jumpers are for enable, full or half step, and control. The the 8pin wiring block is for step and direction inputs, The 4 pin next to it is the power inout 5v,Ground, and up to 50v. The 3 4 pin outputs on the other end are connections for the stepper motors. I may still have artwork for this drive I'll look around and see. I have another single axis contoler that I built first and pushed it until it gave up smoke. I ran it for about 10 minutes at I think 55-60v It's been a while can't remember exactly. I think I still have all of the components needed to build a single board or two I could make you up a kit if your interested. I'll look around and see waht I still have..
    Mar 2004
    190
    Nice board, I'm interested in the artwork if you finally found it..
    Fer
    Oct 2003
    36
    I looked around earlier today and could'nt find the artwork. I have a few more places I can look. Maybe I did'nt throw them out. I have a bad habit of getting rid of stuff once I'm done with it. I think I threw out the single drive board and all it needed was the two chips replace on it. I did however find enough components to build two single boards. I did find the artwork for my breakout board though. If anybody is interested I'll scan it in and post it. All my stuff was done on presensitized possitive photoresist pc boards. So all my artwork is printed possitive.
    Oct 2003
    36
    I found the artwork for the 3-axis driver board and the breakout board. It's the actual art that I used to expose the boards which means it's on transparentcies. It will take me a day or so because I will have to scan it and then go back and clean up the traces. I doubt I'll get a scan good enough from the transparencies that I don't have to clean them up. I'll also have to figure out the component layout because I know I don't have my notes. The driver board is double sided and the breakout board is single sided.
    Mar 2004
    190
    Well, that's one of the major reasons for me to be involved in CNC. Not so interested in wood routing but mainly in pcb milling, just to avoid the hassle of artworks, transparencies, ligths, chemicals and so on. This board will need to be made 'the old way' but i hope that will be the last too
    Fer
    Nov 2003
    244
    about creating a discrete bridge I have some 8 amp steppers I would like to create a drive for how does this work. Do I use the outputs of the L297 as the same way I did the UCN 5804 with a 7414 chip.
    Tom
  1. Bipolar Stepper Motor Power Supply
    By mdframe in forum Stepper Motors / Drives
    Last Post: 01-27-2006, 06:50 PM
  2. Using Zener Diode for Control Voltage?
    By jevs in forum Servo Drives
    Last Post: 03-22-2005, 05:48 AM
  3. 5vdc from paralell port, not enough???
    By thuffner3 in forum CNC Machine Related Electronics
    Last Post: 11-23-2004, 01:07 PM
  4. Series Bipolar and parrallel bipolar?
    By cncadmin in forum FAQ of DIY CNC Machine Building
    Last Post: 09-08-2004, 01:17 PM
  5. Servo's - oversupplying voltage for speed
    By AJ_Mac2001 in forum CNC Machine Related Electronics
    Last Post: 01-18-2004, 05:32 AM
