586,538 active members*
2,868 visitors online*
IndustryArena Forum > Community Club House > Computer Technology > USB, RS232, PARALLEL etc > Need help with Yasnac MX-2 DNC (Drip feed) error
Results 1 to 4 of 4
    Sep 2016
    9
    The machine is a Matsuura MC-760V with a YASNAC MX-2 control. I have no issues with uploading or downloading programs, but when I try to run in Tape (DNC/Drip feed) mode the machine shuts off and the display shows "CP-02 ERROR #39 B0:00:820"
    In the past I could run it in Tape mode using an old laptop with Win XP. That computer broke, and I lost all my settings with it. Currently I'm using a Win 7 64 bit computer with EdytorNC for uploading programs.
    I have tried every parameter and PC settings I could find online to no avail.
    Has anyone experienced something similar?
    Help would be much appreciated.
    Apr 2012
    85
    Re: Need help with Yasnac MX-2 DNC (Drip feed) error
    nwiesz,
    820 alarm means ROM error. In your case #39 on CP-02 board.
    If you're careful you can try to check if the chip is seated correctly in the socket.
    I you get no joy from that try calling Yaskawa for repair advice.
    ***Make a backup of all parameters before attempting any repairs***
    Sep 2016
    9
    Thanks for the feedback.
    We have checked the board and it looks OK.
    I made a few versions of the RS 232 plugs. Some are wired for hardware control. With them loading programs in and out of the machine work fine. When sending the program from PC to the machine or vice-versa it waits until the other is ready to receive and than transfers the file. When trying to use this setting in TAPE (DNC) mode I set the machine up to receive the file, but the PC shows "waiting for machine to respond" and nothing else happens.
    When I use the plug wired for software control (Xon Xoff) the PC or the machine just dumps the file, if the receiving end is not set up ahead of the time. When I set the receiving end up prior to sending the program, it is loading fine. If I try this setup for TAPE (DNC) the machine just shuts off with the earlier mentioned ERROR code and the PC just keeps dumping the file uncontrolled until the end of the program.
    The YASNAC MX-2 has very small memory and for some 3 axis surface milling we really need to use DNC.
    Aug 2009
    1573
    Quote Originally Posted by nweisz View Post
    ...try turning down the Feedrate Override to 0-10% than push Cycle start on CNC......then start sending from PC
  1. Yasnac MX1/2/3 Drip Feed DNC Question
    By DMaz in forum Uncategorised MetalWorking Machines
    Last Post: 12-30-2018, 04:13 PM
  2. Replies: 5
    Last Post: 04-09-2017, 03:57 PM
  3. Drip Feed to Yasnac LX3 vis RS232
    By Zig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-21-2008, 02:24 AM
  4. Tape Drip feed on Meldas50 - P32 Address Error
    By firechcken in forum DNC Problems and Solutions
    Last Post: 05-26-2008, 03:16 PM
