586,551 active members*
3,485 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > 1987 NIkken rotary table minimum index? (CNC-250 DCF + 8800 DX control)
    May 2020
    Hi Guys,
    I am looking to purchase an old (1987) Nikken rotary table with a stand alone controller, but I am having trouble finding some info that I need.
    I need to be able to index 1.5 degrees (240 increments around the part).
    However, it is my understanding that many rotary tables with standalone control can only do 1 degree or 5 degree indexing.
    I've searched pretty hard on google, but have not been able to come up with an answer (or I'm just not using the right search terms)
    Does anybody have experience/knowledge on these Nikken units that may be able to shed some light?
    The unit is a CNC-250 DCF with a 8800 DX control.
    The actual unit that I am looking at is not under power so unable to actually test.
    Thanks!
    Aug 2009
    1573
    Re: 1987 NIkken rotary table minimum index? (CNC-250 DCF + 8800 DX control)
    ...no 1st hand knowledge with this model Rotary Table, but most likely is programmable for 240/1.5 degrees...the Interface to your machine is the real question for automatic operations. Found some photos of the unit (I think)
    Attachment 445108
    Attachment 445110
    Attachment 445112
    good luck,
    DJ
  1. Index table control
    By Kendean in forum Stepper Motors / Drives
    Last Post: 02-24-2013, 04:58 AM
  2. Rotary Table Index Motion Controller?
    By #.0 in forum Linear and Rotary Motion
    Last Post: 01-25-2013, 08:50 AM
  3. GX710 Nikken rotary
    By jimbojones1000 in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2012, 11:15 AM
  4. mazak vqc with nikken 5ax-120 table
    By lfc in forum CNC Machining Centers
    Last Post: 02-03-2010, 12:22 PM
  5. Replies: 8
    Last Post: 11-15-2007, 06:16 PM
