586,500 active members*
3,036 visitors online*
Results 1 to 9 of 9
    Apr 2016
    Tryax turret mill.
    Hi. I have a Tryax turret mill with the Centroid M series control.
    I had damaged conduit to the X and Y limit switches, which I repaired with new glands. Now the machine will not home. The display instruction is to press cycle start, but nothing, no jog functions either. All 4 micro switches, 2 on each axis work ok, e stop etc, no alarms showing, nothing appears damaged or disturbed on the pcb the switches are wired to.
    Can anyone shed any light on this please.
    Dec 2013
    5717
    Re: Tryax turret mill.
    Is it possible that when you rewired one or more of the switches that you wired Normally Open rather than Normally Closed or vise-versa?
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2016
    Jim
    Thanks for your response. They are all nc in normal state and I checked their function at the pcb. So I think I may have damaged something else, although the pcb looks ok there are fibre optics to it, but I don't know how to fault find further.
    Trevor
    Dec 2013
    5717
    Sorry I can't be of more help, but I am out of ideas.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2008
    280
    If nothing happens when you press Cycle Start to find home, then your jog panel is malfunctioning or disconnected.
    If, on the other hand, an error or fault or stall message appears in the status window when you press Cycle Start to find home, then the jog panel is working, and you should find out what the error, fault, or stall message said.
    What happens when you press the F3 key to enter the MDI prompt?
    Status messages might be different if you are running a CNC7 version earlier than 4.00 (i.e., from prior to mid-1994).
    The wiring of limit switches varies with different PLC boards. "Centroid M Series control" could describe any of dozens of configurations built over the course of 26 years. Perhaps you could tell us your control serial number, or post a couple pictures.
    Dec 2009
    521
    My suggestion is you go to the Centroid User Support forum and post a report. F7 Utilities, F7 Create Report
    https://centroidcncforum.com/viewfor...3b57b79704fca7
    Apr 2016
    Thanks for your help. Nothing happens when Cycle Start is pressed, so I will check out the jog panel. I am away from the machine for a few days, but will also check F3 and the serial number then.
    Hi tqscout
    I hope you dont mind the intrusion.
    We have just aquired a mill with a Centroid M-400 controller.
    Have you been able to find anyone who can support your set up, in the UK? We are in Aylesbury Buckinghamshire.
    We need someone to assist in commissioning & training particularly on the Centroid programming side.
    Dec 2009
    521
    Quote Originally Posted by Marcusmole View Post
    Hi tqscout
    There are two good basic Centroid Mill training videos on YouTube. Search Centroid CNC Mill training. Also join the Centroid CNC User Forum. You'll get lots of support there. It's a good control.
  1. freejoth turret mill to cnc
    By mechhamo in forum Australia, New Zealand Club House
    Last Post: 10-27-2018, 09:57 PM
  2. Replies: 0
    Last Post: 04-01-2016, 07:52 PM
  3. TURRET MILL FOR SALE
    By SKENEY in forum Australia, New Zealand Club House
    Last Post: 08-15-2012, 12:59 PM
  4. HM-52 Turret mill
    By pearldiver in forum Australia, New Zealand Club House
    Last Post: 06-23-2012, 02:14 AM
  5. Which CNC turret mill?
    By Toolz_86 in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2011, 09:56 PM
