586,907 active members*
3,028 visitors online*
    Jul 2007
    6
    tig torch water cooler
    I am interested in building a water cooler for my Lincoln 175 tig welder. Does anyone have any plans or ideas they would be interested in sharing.
    Dave
    Sep 2004
    35
    auto heater core (small radiator) and a muffin cooling fan
    Aug 2004
    48
    When I had my tig machine and converted it to water cool I used small parts water from harbor freight. It held about two gallons and a small transmission cooler that was bolted to the back of machine so when the machine fan came on it would cool water. Worked very well for years and then I got the bright idea and sold it. “Bad Move on my part” I also put a check valve, about two PS I in the return line so if the pump failed all the coolant would not drain out.
    Oct 2004
    84
    I bought a Pro-Con pump. I think it's also known as a carbonator pump. Then a motor from Grainger with the correct face to clamp the pump to and then an aluminum core? or ? that thing that looks like a heater core, but comes from an air conditioner. I also bought a squirrel cage blower and motor from Grainger. A five gallon plastic bucket holds water and a little anti-freeze. Return water from the torch passes through an old plastic Pepsi bottle screwed into the bucket lid to confirm flow, over a small probe type temp gauge stuck through the side of the plastic bottle and back to the bucket.
    I'ts worked well for 10 years now. I change the water once a year and clean the pump inlet screen. I only have a 175 amp torch and do mostly thin wall tubing and thin aliminum.
    I can send a picture sometime after FedEx delivers my new camera tomorrow.
    Jul 2005
    19
    I built my first one about 10 years ago. Since then I bought them. Shop Ebay and you should find a good used one for around $250. To me it's not worth the effort, but if you want to trans. coolers & heater cores work well for radiators. Unless you do alot of high amp long duty cycle welding you probably would not need a radiator, just a pump and 2 to 3 gallons coolant. Good luck.
  1. RF-45 Spindle Cooler
    By TPPJR in forum Benchtop Machines
    Last Post: 04-06-2007, 11:49 PM
  2. Water transfer techniques for water table?
    By Knut in forum Waterjet General Topics
    Last Post: 02-02-2007, 04:52 PM
  3. pic of my cooler
    By chrisw765 in forum Fadal
    Last Post: 03-12-2006, 10:43 PM
  4. cpu cooler
    By pyroracing85 in forum Computers / Desktops / Networking
    Last Post: 01-17-2005, 04:12 PM
