586,898 active members*
2,766 visitors online*
    Feb 2005
    117
    Mach 3 zero return problem
    When I press the zero return button X axis and Y axis rapid back to home position. Z axis moves after x an y are at 0.0.
    How do I set up Z to retract to zero position first ?
    Thank you
    John D
    Jan 2018
    1516
    Re: Mach 3 zero return problem
    I don't think you can.
    The way to go about this in regards to a workaround is to set a 'safe Z' height.
    Then when you go to 0 it will move Z first to it's safe height, then move x,y, then move Z to 0.
    I have mine set at 30mm above my work 0.
  1. Return to zero problem
    By kafoowe in forum Machines running Mach Software
    Last Post: 06-29-2014, 04:21 AM
  2. mach 3 does not return to x0y0 at end of cycle
    By sn0wchyld in forum Machines running Mach Software
    Last Post: 01-24-2014, 07:15 PM
  3. Zero return problem?
    By cdhastie in forum Commercial CNC Wood Routers
    Last Post: 09-03-2009, 11:21 AM
  4. Zero Return problem.........
    By ragman in forum Fanuc
    Last Post: 06-06-2009, 01:05 PM
  5. Zero return problem, 11M
    By force2eng in forum Fanuc
    Last Post: 03-09-2009, 01:16 PM
