586,610 active members*
3,565 visitors online*
Results 1 to 20 of 24
    May 2003
    79
    Another High Speed Spindle Design.
    Well it's been a long time since i posted here but i am starting another spindle project and i thought i would share my experiences.
    I have been using a 8,000rpm - 28,000rpm Router like most people but had the following problems:-
    1.Everytime new bearings were fitted i had to play with shims to prevent endfloat.
    2.Bearing life was very short due to vibration and over revving them.
    3.Lack of power at any speed below max rpm.
    4.Runout on the ER16 adapter i am using was excessive.
    After hunting around i eventually found a guy that can supply ER16 extensions that have a step at the bottom to retain the bearings.
    This cost me all off £26.00 so it was worth a go.
    Let me know what you think initially?
    Regards
    Mark
    Attached Thumbnails Attached Thumbnails Er16extension.jpg   spindle assem1.jpg   spindle assem2.jpg
    http://www.weardalecnccarving.co.uk
    May 2003
    79
    I have decided to try 3 deep groove ball bearings insted of the usual angular contact bearings.
    The reasons for this are cost and Max Rpm,The spindle cartridge in total will only cost around £40 excl the machining of course.
    Also other than the problems mentioned in the prev post the router bearings were never a spot of bother if changed regular.
    I would imagine in this instance that the bearing life will be far greater (Higher quality and faster bearings,also the rigidity of the housing and less runout).
    I have attatched the drawing for the spindle body.
    Attached Files Attached Files
    May 2003
    79
    This is the drawing for the front cover of the spindle which also holds the front lip seal.
    May 2003
    79
    I have also picked up the following items.
    2 off - 25mm ID x 35mm OD x 7mm thick double lip seal.
    1 off - Aluminium Pulley with guides 20 tooth x 5mm pitch
    3 off - 6804zz Deep Groove Ball Bearings
    I should start the machining in the next few days,i will post pics as i go along.
    What type of motor do you plan on using?
    May 2003
    79
    The usual cheap Treadmill 2.5hp motor with 7,500 rpm.
    This will be 1:3 on the pulleys so it could achieve 22,500rpm even though i want to max out at 18-20,000rpm.
    I even contemplated going 1:6 using an idler and this way i can stop the motor going into orbit.
    I have the motor and DC controller working through PWM on mach3 using the little opto circuit that was used on the Cnc zone some time ago by J Fettig i believe.
    Apr 2007
    76
    Cool hobby spindle
    Normally, I have found most hobby-spindles could drill or engrave on wood,acrylic or non-metal.:tired:
    It's possible or not if hobby spindle can engrave on metal. example steel,brass,aluminium and so on. How many minimum horse powers does it can? Who know that?
    Cheers
    Samak
    May 2003
    79
    This is the last of the drawings for the Spindle unit.
    Regards
    Mark
    May 2003
    79
    Here is a cross section of the assembled spindle unit.
    103
    Does the ER extension have a metric diameter?
    Can you provide the source for the extention?
    Steve
    Jan 2007
    355
    Mark,
    It looks great.
    I also plan on making an ER16 spindle, but I think I'll go with the angular contact bearings rather than the deep groove variety.
    The AC bearings will handle axial loading better, and 20000 rpms shouldn't be a problem.
    Could you please post your source for the ER16 extensions and treadmill motor ?
    May 2003
    79
    Hmmm Been through this argument before with Angular contact bearings.
    I can not find a source for 20mm id bearings that will run up to 20000rpm + for a reasonable amount of money?
    I have ran my router for thousands of hours and never had a problem with axial load?
    There is only 2 bearings in it but they are run at speeds way beyond there ratings.
    I think you are defeating the object of fitting ac bearings on an er16 spindle because the spindle can only hold up to 10mm dia so not a lot of axial load can be applied anyway.
    I cut everything from wood to metal and never have any problems other than those mentioned in the first post.
    The Dia of the spindle is 20mm and just a nice fit in the bearings.
    Regards
    Mark
    Jan 2007
    355
    Mark,
    Don't interpret my ramblings as criticism, I was just thinking out loud...
    Your points are very convincing, and duly noted.
    May 2003
    79
    Pics of the part assembled Spindles.
    We are building 2 off with different ER16 extensions,Mine has a step to retain the bearings,the other is a std Er16 extension with no step.
    The std extension will have a snap ring to retain the bearings.
    We quickly measured both spindles for runout and bothe were less than .0005".
    Just left with the pulleys to do and the adjuster for the preload.
    Total cost so far is £31 for the spindle so far plus the labour.
    Jan 2006
    481
    Hi
    If bearing life is a issue , have you guys considered a oil mist ( spray ) lubrication system on the High speed spindles
    rather than rely on the grease packed inside these bearings you guys are using.
    cheers
    May 2006
    1469
    I'm following this with interest Mark
    338
    A few thoughts and observations
    This is an idea I have been thinking about exploring for some time. A nicely ground shaft, and collet taper. All hardened... I'm glad someone is working on it.
    AC bearings have the large benefit of being able to set the preload pressure between them. With everything spaced just right... they can run a long time and be very rigid. That requires knowing just how much preload is needed, and actually hitting that target though. With an inexpensive design like this, I imagine it wouldn't be that hard to make a few carefully documenting the changes between them to find the right setup. It would probably take 4-6 spindles... Just a guess.
    All this is moot if he is getting the desired performance out of the deep grove bearings though, so someone else will probably have to do that research.
    The shaft of the collet extensions are available in either inch or metric
    hardinge-workholding
    centaurtools
    parlec
    Most without the steps...
    As far as horsepower to cut material... sfcalc as well as some other little utilities. Ok. this only has numbers for calculating metals but still very useful.
    For spindle lube, I hear it matters a lot as you get into the higher speeds how good of grease you use, and how much/little you use. Do not over grease high speed spindles, and ideally use grease specific for that purpose. The air mist idea is a good one, but means little more hardware. For the air mist, I would also change to a labyrinth seal design instead of rubber seals. This has the benefit of a positive pressure to keep debris out, as well as helping to cool the bearings a little.
    Dale
    Dec 2004
    411
    Quote Originally Posted by rmtucker View Post
    Not having an engineering background, I can only presume that this arrangement requires manual intervention for speed control. Is it possible to utilise a motor / controller arrangement that is electronically controllable without being highly priced?
    I'm happy for this to be split off onto a separate thread.
    Andy
    Drat, imperfection has finally stopped working!!
    May 2003
    79
    Hi
    The speed control is controlled through mach3 using pwm.
    The interface is only 1 optocoupler (about £1) to the Beel dc speed controller.
    It has been shown elsewhere on the cnczone in the past,i will see if i can find the thread.
    Regards
    Mark
    Oct 2006
    24
    Nice job Mark!
    So is the pulley holding the shaft against the spacers and bearings?
  1. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  2. Engraving with High Speed Spindle
    By MichaelHenry in forum Tormach Personal CNC Mill
    Last Post: 06-27-2007, 01:25 PM
  3. High Speed Spindle Attachment
    By yoopertool in forum Hard / High Speed Machining
    Last Post: 06-20-2007, 12:26 PM
  4. High speed spindle friction fit?
    By Rhodan in forum Community Club House
    Last Post: 09-05-2006, 12:57 PM
  5. High Speed Spindle 10,000 to 40,000 rpm
    By whelen in forum Mechanical Calculations/Engineering Design
    Last Post: 09-05-2005, 02:42 PM
