586,950 active members*
2,929 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF2 Alarm 125 - Shuttle Fault, quick fix?
    Nov 2005
    164
    I took delivery of my '02 VF2 last Thursday, its now wired up, all my tooling is in, and I was hoping to cut some stuff today. I was rotating the changer via the ATC FWD button and for some stupid reason I pressed the feed hold button right as the spindle went into the changer. Now I am getting alarm 125 shuttle fault, is there an easy fix for this....ive tried to restart the system, reset the alarms and zero all axes but nothing will take since there is a fault. Im off to a great start!
    Jim
    4826
    Weird, what fault could survive a reboot? A blown fuse maybe?
    Nov 2005
    164
    Checked the fuse, looks OK....I also read something about checking relays k-9-k12 but ive never seen relays like that so how do I know they are bad. Guess I gotta call support.
    Nov 2005
    164
    Problem resolved, I call tech support.....they had me do a tool change restore and zero return single axes (Z). My Z axis was stuck in the changer which confused the machine a bit I guess. Hopefull I wont break anything else!
    Jim
    Feb 2007
    205
    Smile
    type ZZ then press single axis zero return
    Feb 2007
    205
    If that doesn't work .. hit e-stop and get in the machine and push the carousel back to its home position
  1. VF3 spindle high gear fault alarm #117 help!
    By JHR1 in forum Haas Mills
    Last Post: 01-01-2010, 05:39 PM
  2. Alarm 123 Spindle Drive Fault
    By Shotout in forum Haas Mills
    Last Post: 05-27-2007, 05:48 PM
  3. Alarm 235 Spindle Z Fault
    By Gomes in forum Haas Mills
    Last Post: 04-27-2007, 05:26 PM
  4. Alarm 408 Spindle Serial Link Start Fault
    By boricuajdm in forum Fanuc
    Last Post: 04-23-2007, 06:26 PM
  5. Alarm 408 Spindle Serial Link Start Fault
    Last Post: 04-21-2007, 05:19 PM
