586,137 active members*
3,419 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Howto insert the pound symbol?
    Feb 2007
    514
    How do I insert the pound symbol into a format?
    In the following line I want the # to print not indicate the start of the comment.
    fmt "TOOL# " 4 tnote # Note format
    John
    Sep 2004
    145
    i don't believe you can use a # in the format.
    use the number 35 where the tool is called out on the tool change or your tool list;
    "TOOL", 35, etc etc
    Insanity "doing the same thing and expecting a different result"
    Mark
    www.mcoates.com
    Feb 2007
    514
    Thanks Mark
    That's the answer I needed.
    John
    Feb 2007
    514
    Mark it just hit me what the 35 is. It is ASCII screen code!!!
    John
  1. Key Switch symbol?
    By Al_The_Man in forum Autodesk
    Last Post: 07-12-2006, 10:07 PM
  2. Pneumatic symbol wanted
    Last Post: 03-22-2006, 11:21 PM
