587,006 active members*
2,855 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Need help with CNC Router parts Rack and pinion size
    Jan 2013
    228
    I am trying to find a short rack that is compatible with the CNC router parts rack. I need to extend my X axis for my ATC. I have their longest rack and need a few more inches of length. Grainger sells ~1 foot pieces but the size is in modulus and CNCRP has theirs in pitch and degrees.
    does anyone know the modulus of the CNCRP rack, or where I can get a short piece that is compatible? with shipping it would be around $75 for a full length piece of rack from CNCRP, and I'd like to save some $$$$
    Mar 2017
    250
    Re: Need help with CNC Router parts Rack and pinion size
    pitch = Pi x Module
    I'm not sure if the degrees is part of diametrical pitch or not. There are conversions you can do to match.
    Sent from my SM-N960U using Tapatalk
    I think it's 20° PA, 20 pitch.
    Mod rack is metric, which is different.
    Feb 2005
    829
    Email cncrouterparts they will give you the info you need. They may even have a piece the size you need.
    It states on their website that it's 20° PA, 20 pitch.
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. Alternative Use Of CNC Router Parts Nema 34 Rack and Pinion System
    By JidoukaSS in forum Uncategorised MetalWorking Machines
    Last Post: 05-05-2014, 05:36 PM
  3. CNC Router Parts Rack and Pinion Development
    By ahren in forum DIY CNC Router Table Machines
    Last Post: 04-01-2014, 03:15 PM
  4. CNC Router Rack and Pinion
    By Hari Kristianto in forum Techno CNC
    Last Post: 03-23-2010, 03:08 AM
  5. Torchmate Rack and Pinion Size
    By techie4971 in forum Torchmate
    Last Post: 07-31-2007, 06:04 AM
