586,700 active members*
3,150 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Heidenhain TNC 150B Problem on Bridgeport Interact 1
Results 1 to 8 of 8
    May 2006
    Hi, I have a problem with a TNC 150B on an Interact 1. When the machine is turned on the control goes through it's start up sequence apparently normally and ends up at it's normal POWER INTERRUPTED display with the normal various position coordinates. All the Leds are lit on the panel as normal, but when I press CE to proceed to the referencing stage nothing happens. I have tested all of the buttons on the front panel and they all work as they should. I have also tested the 24v DC supply and all of the inputs i.e. reference switches, limit switches etc. I think the fault is probably in the control itself but if anyone has any ideas on where the fault may lie or what may be causing it I would be grateful.
    Thank you
    S P Hill
    Nov 2016
    30
    As stupid as it sounds check all the emergency stops are out. I thought it was CE then cycle start to punch through each referencing but I maybe misremembering
    Quote Originally Posted by sphill View Post
    Thank you
    S P Hill
    May 2006
    Re: Heidenhain TNC 150B Problem on Bridgeport Interact 1
    Hi, Yes I checked the emergency stops and just about every other reference and limit switch I could find on the circuit diagram. I have also checked the supplies 110ac and 24Vdc and all of the overloads on the motors etc. The control just ignores me pushing the CE button and will not proceed to the next stage. I have come to the conclusion that the fault is in the control itself but I am open to any help or advice that would help me solve this problem.
    Thank you for your reply.
    1121
    When you press CE do the LED's go out ?
    Is this machine new to you? IOW has it run before?
    the process is CE, Power Enable, then run[Z home], run[[Xor Y home] ,[Yor X home]
    If you hit CE and the leds go out, and the screen shows the axis waiting to home, hit power enable, then when you hit 'run' it does nothing, it is most likely the EMO.
    Check the oil
    If the LEDS don't go out, then something is internally wrong
    May 2006
    Hi Gus, thanks for your reply. In answer to your questions.
    No, I have had the machine for over ten years and yes it has run properly before. It started out with a TNC145 control but that died and I upgraded it to a TNC 150B at least eight years ago and it has worked fine up until about 18 months ago when it was working one day and the next it was like it is now.
    When I hit CE it does nothing, the leds do not go out and the screen does not change. As you can see from my earlier posts I think that I have checked pretty much every thing that I can think of, including the lube oil.
    I had come to the conclusion that there was something wrong with the control itself rather than the machine as you seem to have at the end of your reply.
    Thanks Simon.
    Nov 2016
    30
    What happens if you disconnect the axis from the controller one by one? Might be a way of working out if its the controller or something else.
    I will hopefully have a TNC145 becoming available once I get up the courage to fit the TNC151 and input the parameters. It is concern about getting the latter wrong that is stopping me. Drop me a PM if you are interested.
    Andrew
  1. Bridgeport Interact with Heidenhain 145 - Z Axis weird problem
    By raynr in forum Bridgeport / Hardinge Mills
    Last Post: 03-02-2018, 08:06 PM
  2. Bridgeport Interact 520V/Heidenhain TNC155Q problem
    By RS232 in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2016, 07:47 PM
  3. Bridgeport Interact 1Mk2 Heidenhain TNC151 4th axis encoder problem
    By hazelchase in forum Bridgeport / Hardinge Mills
    Last Post: 09-25-2014, 04:27 PM
  4. Bridgeport Interact 412/Heidenhain TNC 151 HELP?
    By larrynsr in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2012, 08:21 PM
  5. Heidenhain Tnc 150b, 151a, Or 151b Control
    By Gute in forum MetalWork Discussion
    Last Post: 09-17-2007, 02:07 PM
