586,728 active members*
3,688 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > C5 ground ball screw sources
    Jul 2019
    Cool C5 ground ball screw sources
    Apologies, I am new on the forum and finding it challenging to get good search results
    I am hoping to get suggestions on suppliers of C5 grade ground ball screws - all suggestions appreciated
    Nov 2013
    4447
    Re: C5 ground ball screw sources
    I have bought seconad hand and new old stock from this supplier in Korea:
    https://www.ebay.com/str/industrialpartsshop
    Craig
    Jan 2016
    79
    Akn99,
    Two sources that I've engaged in the past for C5 ground screws are below. I can speak to the lower cost option (Terry Machinery), screw quality is good, end machining is good. I have not purchased from the other source. Good luck in sourcing your screws. I would recommend Terry Machinery.
    Source 1
    Terry Machinery - about $200 for a 28 inch 2005 C5 ground screw with double nut with full end machining. Price did not vary much due to length so $200 per axis is about what you'll pay including UPS air freight from China. I spent $580 total to my door for 3 screws. Took about 5 weeks total from quote to receipt.
    Sophia Xie
    Changsha Terry Machinery Co.,Ltd.
    Tel: 0086-731-85782665
    Fax: 0086-731-85515405
    Cell:008613667367982
    Email:[email protected]
    Source 2
    TBIMOTION LINEAR RAIL & BALLSCREW Store on AliExpress
    $315 for a 700mm C5 ground 2505 screw with double nut
    $310 for a 800mm C5 ground 2005 screw whit double nut
    $230 for a 450mm C5 ground 2005 screw whit double nut
    $310 for UPS air freight to USA. (Expensive due to Covid 19 flight shortages, they commented that normal is about $180).
    I cannot speak to quality on these, as I did not purchase.
    Nov 2013
    4447
    some new-old stock:
    http://www.automation-overstock.com/
    Craig
