586,907 active members*
3,049 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Adaptive Keep Down & Dog Leg Rapids
Results 1 to 14 of 14
    Mar 2012
    1570
    I wanted to take a moment and explain what is going on here.
    1) When does the tool go to clearance to re position with adaptive toolpaths.
    In the image below I have the same adaptive pocket, same toolpath settings, just using different tools sizes
    You see that the smaller tools go to clearance between passes and the larger tools stay down. What's happening in the background is a formula based on the distance the tool has to travel for the next pass. This formula determines if the tool goes to clearance or stays down.
    You'll notice in the second picture, the pocket provide is a little different. In this image you see how the smalles tool still needs to go to clearance but as we step up in tool size the tools starts to stay down more.
    So if the tool goes to clearance between passes the distanced between passes is greater than the formula allows and forces the tool to retract. As the distance between passes get's closer the tool stays down.
    This formula is done in the background and at this time there is no user override. What you can do to keep the tool down is to use a larger tool.
    2) When doing reposition moves how do you avoid dog leg rapids
    In the current version of BobCAD, you now have a rapid override option. Allowing you to map your rapid moves to a high feed move. Turning this option will replace all your G00 reposition moves with a G01 move at a user defined feed rate.
    Attachment 441746
    Attachment 441748
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Oct 2016
    128
    Re: Adaptive Keep Down & Dog Leg Rapids
    Quote Originally Posted by aldepoalo View Post
    Attachment 441746
    Attachment 441748
    Best option is to quit using bobcad. The problem I always had with bobcad is how it tells you how you need to cut things instead of allowing the user to dial in how it computes the toolpath the way you want it too.
    Dec 2008
    4548
    Your 15 years too late Dillon... You have no options
    BobCad has a TOOLPATH EDITOR!!!!! lol I can actually edit the calculated toolpath.
    It doesn't get any more "how you want to do it" than that....
    Oct 2016
    128
    Quote Originally Posted by BurrMan View Post
    No bobcad is 15 years behind. I use mastercam. I could program by hand faster than using bobcad.
    Dec 2008
    4548
    Ahhhhh! MasterCam…. No WONDER...…
    [EDITED]
    Yup. We all know that....
    Oct 2016
    128
    Ahhhhh! MasterCam…. No WONDER...… you are a douche bag!!!!
    Lmao ok. I own both but believe what you want. I don’t hobby with a ****ty program. I print money all day and night with real machines and real software that can output reliable simultaneous code not just 2d trash.
    Dec 2008
    4548
    That's because you're a TIGER!!!! Super rich, and fancy!
    Oct 2016
    128
    Actually no. One man shop running 5 machines but yeah you also believe that bobcad is a powerful software.
    Dec 2008
    4548
    Quote Originally Posted by dillonfitz View Post
    Uhhhh….
    Pfftttt…. You real bling bling all over the earth like that.... You are THE MAN!!!!
    I can only wish I was like you....
    Oct 2016
    128
    Uhhhh….
    You really have some deep down personal issues. Once you figure out how to handle yourself maybe you will figure out how to further your future.
    Dec 2008
    4548
    Really givin to us know nothings... putting us in our place... We can all see now just WHAT we might be able to aspire to someday.....
    Apr 2009
    3376
    I feel so inadequate after reading this.I could only wish Dillion.
    Mar 2012
    1570
    Here is the video version on the same topic.
    https://www.facebook.com/allen.depoa...1674712844217/
    Al DePoalo
    Sep 2012
    76
    Thanks Al - nice video, and I learned a little more.
  1. Adaptive Toolpaths - V26 vs V28
    By nlh in forum BobCad-Cam
    Last Post: 01-06-2016, 01:31 PM
  2. Adaptive Ruf questions
    By moldmker in forum BobCad-Cam
    Last Post: 06-26-2012, 12:01 AM
  3. Adaptive Roughing Sample
    By aldepoalo in forum BobCad-Cam
    Last Post: 06-14-2012, 02:48 AM
  4. adaptive feedrate
    By camtd in forum EdgeCam
    Last Post: 11-13-2006, 11:59 PM
