586,652 active members*
2,995 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Welded frame fixed gantry CNC router
    Oct 2014
    10
    Hello, I wold like to show off the current progress on a machine I started while I was in trade school . The basis for the machine was a compact design with rigid components without spending lot of money . I also Took inspiration from the machines built by This old Tony and Wade'O design.
    The frame it is made up of 2"x 2" 0.250" wall square tube and the X-axis uses 3"x 5" 0.375 wall rectangle ,all the rails are 20mm , the ballscrews for the X and Y-axis are 20mm SFU2010 .
    I plan on machining aluminum and some steel so I chose a 2.5Kw , 24k rpm spindle and Nema 23 425 Oz.in for the stepper motors .
    The travel for the machine is 13.5" X-axis ,9.5" on the Y and 6.1" for the Z .
    If anyone has any tips or insight please let me know .
    I will keep posting picture updates.
    Oct 2014
    10
    Re: Welded frame fixed gantry CNC router
    Z-axis components
    Oct 2014
    10
    Feb 2005
    829
    looks great!
  1. Welded steel frame router build
    By jones in forum DIY CNC Router Table Machines
    Last Post: 09-06-2023, 09:57 AM
  2. Lessons in overkill! Welded steel, fixed gantry router
    By mcentric in forum DIY CNC Router Table Machines
    Last Post: 10-23-2018, 08:53 AM
  3. Welded Fixed Gantry Router/Mill
    By robotmickey in forum Benchtop Machines
    Last Post: 11-19-2017, 06:56 AM
  4. Fixed gantry 500mmx500mm (4mm domex frame) build
    By Larduspr in forum DIY CNC Router Table Machines
    Last Post: 03-07-2014, 01:02 PM
  5. Fixed gantry router
    By KTP in forum DIY CNC Router Table Machines
    Last Post: 04-17-2011, 11:44 PM
