586,991 active members*
4,009 visitors online*
    Sep 2013
    plasma arc still on after end the pierce
    When my Cnc plasma cutting pierces the arc sometimes working good and sometimes no, good main the arc on and off time working at right time, but sometimes ( off ) not working right and late to end arc, machine go to the next Pierce and arc still on , l change relay in THC card with new relay but still arc on right and arc off is late, I tried to connect the arc tourch direct with the lgk power source without THC card also still the problem arc on right but arc off late, how can I fix it please
    May 2015
    686
    Re: plasma arc still on after end the pierce
    You need to provide a lot more info.
    What Plasma? Machine Torch? Pilot Arc Start or HF start?
    What Controller?
    What THC.
    Rod Webster
    www.vehiclemods.net.au
    Apr 2003
    540
    Lots more info needed. Include software to the list above. Possibly a software issue. Check your code before running it first and see if all the correct on/off code is included and your pierce delays etc are correct before you start trouble shooting hardware.
    Feb 2011
    36
    Quote Originally Posted by yamen moner View Post
    This delay has a some LGK plasma cutters. Delay depend from the capacity of the elctrolythic capacitor in the plasma start input. Usually we find this cap and change to lower value (was for example 470 uF - change to 22 uF). Capacitor is on the main control board - just trace a start signal from connector on the cutter face panel to this PCB and find this cap (near this cap usually there are a rectification bridge - 4 diodes)
    Best Regards!
    Andrew.
  1. Replies: 2
    Last Post: 12-09-2019, 08:54 PM
  2. Unable to pierce with plasma
    By Bradnicent in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 10-31-2018, 04:27 PM
  3. SteelTailor Plasma Nozzle is getting damaged at the first pierce itself?
    By Steel Tailor in forum Other Machine Topics
    Last Post: 05-25-2015, 10:22 AM
  4. PIERCE PLASMA help?
    By tibet in forum Waterjet General Topics
    Last Post: 10-07-2010, 11:49 PM
