586,884 active members*
3,783 visitors online*
Results 1 to 11 of 11
    Nov 2019
    11
    Where to BUY End Mills for a Spindle
    Finally got my Avid PRO 48x48 up and running. I have the 2.2kw spindle with ER20 Collets.
    I come from a metal machining background. Where is everyone getting Carbide End Mills?
    Some of these CNC ROUTER specific bits are way overpriced compared to traditional end mills.
    Any insight?
    Re: Where to BUY End Mills for a Spindle
    End mills and router bits have different geometries, for cutting different materials.
    I usually use Onsrud, Vortex, or Amana. No, they are not cheap.
    Feb 2005
    829
    I get carbide and HSS from Toolstoday.com. I have had alot of great outcomes with the single flute HSS tools, inexpensive and sharp as hell. All the HSS tools are more forgiving of mistakes as they are more flexible then the carbide tools.
    Sep 2006
    6463
    If you go on UTUBE and browse the vids by Stefan Gottenswinter he advocates 3 flute carbide end mills and runs them dry because he like to not have the muck to clean up afterwards.
    For example, he did a test run in steel on a manual mill and ran an 8mm 4 flute carbide roughing end mill at 6mm depth of cut, full width, with a feed rate of 90 mm per min without coolant.......1,300 rpm.
    A second test was with a 3 flute carbide end mill, 45deg helix, 1,000 rpm, 7mm depth of cut and a 40mm/min feed rate in 304 stainless.
    Ian.
    Feb 2005
    829
    handlewanker, 3 flute carbide is great at 1300rpm, Spindles can't turn below 8,000RPM normally.
    Sep 2006
    6463
    Hi....I did say the UTUBE example was on a manual mill, something like a BF20 or other..........if you are using a watercooled high speed spindle......8,000 to 24,000 rpm...... then you'll have to use some other method, like a conventional driven spindle with a VFD etc.
    Ian.
    Nov 2013
    4462
    I use a lot of very small endmills mostly from Kyocera Tycom and I get them at good prices
    https://www.ebay.com/str/carbideplus
    Craig
    Jul 2017
    I get all my cutting tools, collets, etc. at MSC Industrial (MSC Industrial Supply - Metalworking tools and MRO Supplies). I typically use 2-flute HSS miles for all the work I do. Accupro is my preferred brand.
    Sep 2005
    1740
    Try Amazon, MSC is so high priced I usually spend $20-30 USD sometimes more and they are decent bits. Never more than 2 flute with these High speed spindles.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Apr 2020
    Nov 2015
    16
    I have been getting the bulk of my carbide cutters from Yonico on eBay
    cheers
    Sean
  1. ISO20 ATC spindle for Mills and Routers
    By dwalsh62 in forum News Announcements
    Last Post: 02-13-2014, 01:38 PM
  2. New to Mills
    By Redgoatfab in forum Benchtop Machines
    Last Post: 01-06-2012, 04:53 AM
  3. OLD K&T mills spindle problem...
    By masonbcaldwell4 in forum Uncategorised MetalWorking Machines
    Last Post: 03-06-2009, 03:17 AM
  4. Hot spindle drive motors: X mills, Tormach, IH
    By bilinghm in forum Benchtop Machines
    Last Post: 07-12-2008, 02:17 AM
  5. Face Mills intstead of end mills
    By balal in forum MetalWork Discussion
    Last Post: 07-01-2006, 06:35 AM
