586,721 active members*
3,546 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > How to reset the new M30 Counter on the lathe in PP
    Oct 2010
    670
    In the newest version of PP (2.4.2) when running the lathe, I now have some details over in the right window showing M30 A:xxxx B:xxxx. Appears that every time the program finishes it adds to the counter.
    How do I rest this or change the numbers for A & B. It has the same thing for M99 A & B.
    Awall
    CoolCNCStuff.com
    The Body Armor Dude - Andrew
    Oct 2010
    670
    Re: How to reset the new M30 Counter on the lathe in PP
    Found it on page 3 of the PDF notes. It came out with 2.4.0
    https://www.tormach.com/support/soft...release-notes/
    I wish it had a way to "adjust" it. Say you are on part 34 and it messes up. Your only option is to reset it.
    Nov 2012
    591
    The documentation goes on to say:
    To change a counter value explicitly, use a G10 command: G10 L99 P~ Q~
    l P~ selects the cycle counter to change. Use any of the values detailed in the following table.
    Cycle Counter P~
    M30 A 0
    M30 B 1
    M99 A 2
    M99 B 3
    l Q~ specifies the value to set the cycle counter. If Q~ is omitted, the cycle counter is incremented by 1.
    For example, if you program G10 L99 P2, the M99 A cycle counter increments by 1
    It seems that, with G10, you can set it to whatever you want.
    Oct 2010
    670
    Quote Originally Posted by jwatte View Post
    Yep, it works. Just dialed it in. Will have to create a cheat sheet for this but a good feature.
    Nov 2007
    2151
    Quote Originally Posted by smokediver576 View Post
    I was reading that they increased the rapids speed for lathe with this upgrade.
    I noticed the rapids on the 24r also changed or are displaying a different value anyway. Now it goes over 260 and before it was little over 200 . This was not detailed in release notes so I don't know if it was intended or not.
    Nov 2007
    2151
    Quote Originally Posted by mountaindew View Post
    Sorry, this was an incorrect observation! I was looking at feed rate displayed! When x and y are both traveling at max rate. The combined axis speed is higher then the maximum speed of just one axis. Duh
  1. PLC: 0030 (TOOL COUNTER ERROR), FAGOR 8055i can't reset
    By vladimir1409 in forum Fagor Automation
    Last Post: 04-06-2017, 01:02 PM
  2. EMCO 3 lathe counter shft pulley
    By aam-edm in forum EMCO Lathe
    Last Post: 06-07-2013, 04:20 PM
  3. Help - Conquest ST-20 Part Counter Reset
    By Wolves in forum Hardinge Lathes
    Last Post: 02-15-2012, 12:42 AM
  4. Part Counter Reset
    By Outlaw6700 in forum Milltronics
    Last Post: 02-27-2010, 12:00 AM
  5. Reset Parts Counter
    By martsto in forum Milltronics
    Last Post: 09-18-2007, 04:59 PM
