586,608 active members*
3,707 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Inlay pocket help
Results 1 to 9 of 9
    Apr 2011
    68
    Inlay pocket help
    Hi Guys , attached is a drawing of what i want to cut a pocket for . This is for a backgammon board inlay , the pocket needs to have a pointed cut on the end . When i draw it the end cuts round , can anyone point me in the right direction . Bobcad v29 version
    Ed
    Dec 2013
    5717
    Re: Inlay pocket help
    It's not possible to cut a pocket with a point that is smaller than the cutter radius. About the closest you can come to a sharp point is with a laser, a sharp knife, or a really tiny cutter.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2008
    1838
    The only way to avoid getting the cutter radius is to use the V Carve option which you should have with V29.
    This toolpath needs a V shaped tool for the finish and you will need to machine an angle (Chamfer) on the inlay piece to get a nice fit.
    Example file attached that may be of use to you
    Regards
    Rob
    Attached Files Attached Files
    Jun 2008
    1838
    Quote Originally Posted by Jim Dawson View Post
    V Carve will do it
    Here is an image of how the inlay would need to be machined, viewed from below
    Regards
    Rob
    Apr 2011
    68
    File will not unzip or open
    Apr 2009
    3376
    Opens fine here ??????
    Jun 2008
    1838
    Are you on Windows or Mac PC?
    If windows just click on the file and you should get a small dialog like this
    Select the Open with option and you should be able to see the BobCAD file as below,
    The file was created with V28 Pro so unless you are using a Demo version of V29 which won`t open a licensed version file you can either Copy and paste the BobCAD file and then open in your V29 or just click the Open option and it should automatically launch your V29.
    Hope that helps
    Regards
    Rob
    Jun 2008
    1838
    Quote Originally Posted by jrmach View Post
    Hi James, yes, I don`t see any reason why it wouldn`t open, at a bit of a loss
    Regards
    Rob
    Apr 2011
    68
    Got it , Thank you Ed
  1. Inlay
    By NFrankN in forum PhotoVCarve and VCarve Pro
    Last Post: 02-26-2019, 11:21 PM
  2. Advance Pocket or Offset Pocket
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-31-2013, 07:46 AM
  3. Replies: 1
    Last Post: 11-30-2011, 07:51 PM
  4. Help with CNC for inlay
    By pixel8tryx in forum Musical Instrument Design and Construction
    Last Post: 04-03-2010, 04:22 AM
  5. inlay and pocket fitting problem
    By daisydog in forum Mastercam
    Last Post: 08-23-2007, 05:09 AM
