587,006 active members*
2,744 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Nema 34 12.0 Nm(1699.68oz.in) or 8.25 Nm(1168.53 oz.in)????
Results 1 to 12 of 12
    Jan 2012
    163
    I'm going to replace my damaged Nema 34 with a new one, I would like to ask what would be better for my Z axis PM-25MV Mill Nema 34 with 12.0 Nm(1699.68oz.in) or 8.25 Nm(1168.53 oz.in) it's like all most the same price for the bigger motor, I'm not sure if there is any pros or cons for ether one
    https://www.amazon.com/gp/product/B0...PTXF2T90&psc=1
    or
    https://www.amazon.com/gp/product/B0...GWISS7BL&psc=1
    Jan 2008
    1538
    Re: Nema 34 12.0 Nm(1699.68oz.in) or 8.25 Nm(1168.53 oz.in)????
    What is the inductance of each motor?
    What voltage will you be driving it with?
    With steppers, bigger (higher oz.in) is often not better. You need the torque to be available at reasonable rpm.
    Jan 2012
    163
    I have a 60 volt dc power supply I wanted to use, the Motor Specification are listed in the links I added: https://www.amazon.com/gp/product/B0...PTXF2T90&psc=1 or https://www.amazon.com/gp/product/B0...GWISS7BL&psc=1
    May 2008
    1185
    For the PM-25 a 640 oz 6A Nema 34 is already over kill.
    A 1600 is crazy.
    Total over kill size would be a 900 oz. The Z runs fine with a Nema 23 570 oz.
    youtube videos of the G0704 under the name arizonavideo99
    Jan 2012
    163
    I'm thinking bigger is better this is why I’m asking, please correct me if I’m wrong it would be easier and work less with a bigger motor I know 8.25 Nm(1168.53 oz.in) can handle it but for all most the same price I can get the (1699.68oz.in) I'm not sure if there is any pros or cons for ether one
    Smaller motors run faster and smoother. Once you get to a certain point, anything larger actually will decrease performance.
    Jan 2018
    1516
    I had problems with a 1600oz on mine using 60v psu. Forget it!. Terrible power and resonance issues.
    I now have a 1080oz 8 wire nema34 wired in parallel. inductance of 3.5 and runs smooth and quiet up to 2000mm/min which is enough for me. My Z is set up pretty tight.
    https://www.ebay.co.uk/itm/1-PC-Nema...72.m2749.l2649
    The drivers I'm using are cheap ones so I'd probably get more from it with better ones.
    Jan 2012
    163
    larger they have more power and torque?
    Jan 2008
    1538
    I suggest you search and do some reading on stepper motor selection.
    These questions have been answered many many times here on cnczone and elsewhere.
    Have a look at stepper motor torque curves.
    Don't buy anything until you understand whether it is a good choice.
    Mar 2019
    51
    Beware, I was in same path as you but got some light, please see this post: https://www.cnczone.com/forums/stepp...99300-cnc.html
    Feb 2008
    521
    Quote Originally Posted by rmachinist View Post
    Unless you are trying to shift huge bulk, quickly and have the power available to service that performance, a smaller / lighter motor will perform just as well. The 2nd of the two above noted motors has the lower inductance and so would match your power supply better although it still would be slow compared to a 'lower rated' oz/in motor that is better suited to the power available.
    They have more holding torque, when they are NOT spinning. Once you get over a few hundred rpm, they often have less torque than much smaller motors.
  1. Stepper motor upgrade NEMA 34 or NEMA 42?
    By rogerfries in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2015, 04:59 AM
  2. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  3. CHEAP 68oz steppers on ebay... $6.00 Brand Name
    By dbtoutfit in forum Stepper Motors / Drives
    Last Post: 01-29-2011, 07:02 PM
  4. Standard Nema 34's vs Nema 34's with encoder/controller.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 03-16-2006, 05:03 PM
