586,589 active members*
2,549 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > FANUC Oi Mate TC controller Threading problem
    Dec 2019
    Unhappy FANUC Oi Mate TC controller Threading problem
    Can someone really help me to solve this. My CNC lathe had once executed a G33/G32 Threading cycle. Suddenly, whenever I run a Threading Cycle, it just reads the line of the threading cycle on the screen and stays there with spindle rotating but no tool motion. Below is a program I used to test the Lathe once more:
    G28 U0 W0;
    T202;
    G00 X20.0 Z5.0;
    G76 P030060 Q100 R0.15;
    G76 X16.93 Z-30.0 P1533 Q500 F3.0;
    G28 U0 W0;
    M05;
    M30;
    Please, what could be the problem?
    Dec 2008
    3110
    Re: FANUC Oi Mate TC controller Threading problem
    dont see a Speed or spindle ON command
    check manual for 1st G76 line P030060
    03= # of finish passes
    60= angle of flank approach(I use 29 for 60° metric thread)
    Dec 2019
    Quote Originally Posted by Superman View Post
    Thanks Superman. I used a Spindle On and Speed command. It still did the same thing( Tool motion stopped st the 1st line of executing G76 Or G32..
    Can you suggest a better Command for P030060 line?
    Feb 2011
    353
    try removing the point from the R value
