586,780 active members*
7,700 visitors online*
    Sep 2006
    296
    Drill tool holding
    Recently purchased a '95 Citizen E 25J . I had never operated a swiss lathe before so bear that in mind. Have it running fine and dandy.
    However i am curious what most people are using to chuck drills into the tool holders with on these machines.
    I had to make some custom sized sleeves to mount the drills into the bore of the tool holders. Its working fine but this is not a good way to operate long term. Especially when i need to make quick setups in the future. On all my other CNC lathes i just buy ER32 collet holders with a straight shank and mount them into the tool holder bores. However there is not enough room on this Swiss machine to add an ER collet chuck and still have a drill longer than maybe 1/2" mounted in it.
    Feb 2011
    353
    Re: Drill tool holding
    most of the holders that i use are er16 collet sleeves mostly from genswiss
    Sep 2006
    296
    I do have some ER16 chucks with straight shank. Still lose almost 1" of Z from the collet nut sticking out but considering the small parts that probably will be ok for most jobs.
  1. Bridgeport boss 6 quick change tool holder not holding tool properly.
    By TBCind in forum Bridgeport / Hardinge Mills
    Last Post: 04-04-2017, 06:56 PM
  2. Drill / 5C Collet Holding
    By dneisler in forum Tormach Slant Lathe
    Last Post: 08-15-2016, 01:43 AM
  3. Forgetting It's Holding A Tool
    By ALushMachinist in forum WinCnc
    Last Post: 09-15-2014, 11:34 PM
  4. Which chuck for holding drill bit?
    By clanbuster in forum Vertical Mill, Lathe Project Log
    Last Post: 08-27-2011, 08:30 PM
  5. Taig tool holding
    By rich_cree in forum Taig Mills / Lathes
    Last Post: 11-16-2010, 03:17 PM
