586,551 active members*
3,415 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Speeds, Feeds, and Strategies for Bench Top Mills
Page 13 of 13 3111213
Results 241 to 245 of 245
  1. #241
    Jan 2018
    1516
    Quote Originally Posted by CL_MotoTech View Post
    A high capacity cast cover shown below, it didn't last (note the large hole that let all the water out) and cost a ton of money as we had to import it from the UK. My cover is higher capacity yet and won't suffer the same porosity issues as a cast one.
    Quality from the UK is very poor.
    We can't cast anything properly, or do it too much on the cheap.
    The latest is the trams in B'ham had to be shut down, they keep cracking.
    People too thick to realise that cast aluminium is too brittle to use for the wheel bogies and can't take the weight.
    'proper' strength in steel too costly but corner cutting has bit them in the ass.
  2. #242
    Re: Speeds, Feeds, and Strategies for Bench Top Mills
    That failed cover is actually magnesium, a rather nice part if you drain your water after every ride. Pretty worthless if you don't, despite the nearly $200 price. My cover suffers from the same CNC billet issues that all CNC'd parts do, they look like bricks even when whittled down. Castings are so much nicer, IMO. I haven't yet found the patience for doing my own castings, maybe some day...
  3. #243
    Pretty happy with the Side B. There are a couple of little things, as usual, my programming is the weakest link.
  4. #244
    Oct 2013
    543
    I think that looks beautiful...I sure couldn't do something like that.
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  5. #245
    Not exactly a CNC machine update, but the fruits of the CNC machine in this thread is paying off. We are close to race time. A little less than two weeks to go!
    We adjusted the squish on the heads, we added some o-ring grooves to energize the base gasket spacer, and along the way we got the Kurbside van body on the 2010 Express chassis and it tows the trailer we built back in 2001 out of Kurbside bodywork and a custom chassis. The machine work was done on the 0704, the rest of it was sweat and hard work.
  1. Replies: 3
    Last Post: 12-08-2017, 12:42 AM
  2. HDPE feeds, speeds and mills
    By Erant in forum Glass, Plastic and Stone
    Last Post: 10-07-2015, 09:01 PM
  3. Speeds and Feeds/Small End Mills
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 02-13-2015, 07:45 AM
  4. End Mills and Feeds n Speeds
    By Simon Wells in forum CNC Tooling
    Last Post: 03-20-2012, 06:11 PM
  5. Opinions needed on cnc bench top mills
    By M4RK_23 in forum Benchtop Machines
    Last Post: 01-10-2006, 05:48 AM
