586,675 active members*
2,605 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > P1 centurionV ATC not working
    Feb 2020
    I just get an P1 by now i repair all mechanical stuff and is working ok but ATC not work at all, if i get separated comands and go to ATC manual it works it go home and go fwd and reverse but no creep speed, no orient i think ATC macro is corrupt or something in configuration. Now i get an extra HDD and make an back-up system also left original HDD as back up and now is running under compact flash memory, but ATC not run i check orient sensor, TC sensors, TC valves and all work ok and in diagnostic windows it shows working, if some one with a machine working can share me a system back-up or configuration back-up i think could solve problem. When i get this machine it has an x encoder wire damaged and machine was junked now is alive just need ATC fix.
    I will preciate any help.
    JP
    Jun 2010
    132
    Re: P1 centurionV ATC not working
    Do you have the original Hard Drive and the compact flash running?
    If so does it boot off the cf?
    It sounds like it cant find the atc macro or corrupt like you stated.
    In the power parameter screen you have to have the correct path to the macro.
    I have a Pi E with a 6 position atc.
    Ron
  1. CNC not working
    By marmaz3 in forum Chinese Machines
    Last Post: 06-07-2019, 01:05 PM
  2. Setting drills, ID tools and back working/end working tools
    By jonathan2jones in forum CNC Swiss Screw Machines
    Last Post: 04-22-2017, 01:11 AM
  3. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  4. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  5. Don't know what I need to get this working, need help!
    By leirpytt in forum CNC Machine Related Electronics
    Last Post: 04-13-2008, 08:41 PM
