586,812 active members*
6,915 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > How to tell the difference in Black ABS VS Black Delrin?
    Nov 2006
    45
    I didn't seperate these when I was machining some sheets. I put the ABS with the Delrin on the shelf. I'm having a hard time deciding on what's the ABS is. Is there a tell tail sign of ABS? I know that its usually lighter in color. It cuts a little different, but I want to be sure. Any help would be appreciated.
    Jimmy
    Jul 2005
    12177
    Take some chips or cut off a thin sliver and burn them.
    Delrin is an acetal plastic and when it burns it does it with a clear, almost invisible flame, and creates formaldehyde which has a very sharp smell.
    ABS has butadiene and styrene in it, same as synthetic rubber and polystyrene.When it burns it produces a lot of sooty smoke and has something of a burnt rubber smell.
    And don't inhale too much of any of the smoke.
    Nov 2006
    45
    Thanks, that sounds like a good way to check it.
    I appreciate the help!
    Jimmy
    Similar issues, additional solutions
    This is just a 'by the way' post.
    I see that this is an old post, but we had this same issue, and our supplier sent out a guy to look and he did some testing and was able to separate the materials. He did the 'burn' test mentioned above, but he also weighed the parts. ABS is lighter than Acetal by about 15%. Also, he has some liquid, I think it was a methylene chloride, and he put a very small amount on the parts. It doesn't touch the Acetal, but melts the surface of the ABS. Very cool to watch.
    We have used these guys for years, and they do a good job. This kinda put them over the top in our minds. I bet lots of plastic places could have shown us this, but these guys did - Industrial Plastic Supply
    Oct 2005
    2392
    Cool info, thanks!
    I usually measure and calc cc's (volume) and then weigh it, the specific gravity tells a lot.
    With Delrin and ABS you should be able to tell from the softness if you have pieces of each on hand. Tap it with a metal object (screwdriver etc) Delrin is hard enough to "tap" ABS and PE HDPE etc will "thunk" being softer.
    And the best tip is when you buy new stocks write the material name on the 4 edges of the stock with a sharpie pen!
    Jul 2007
    1602
  1. EMC development black hole
    By Vigilant in forum LinuxCNC (formerly EMC2)
    Last Post: 02-08-2007, 02:28 PM
  2. RFQ - Black Delrin - 20-30 units.
    By Spitlebug in forum Employment Opportunity
    Last Post: 04-01-2006, 01:22 AM
  3. black coated studs
    By pyroracing85 in forum MetalWork Discussion
    Last Post: 02-19-2005, 03:11 PM
  4. A Black Pipe Question
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 06-17-2004, 06:11 PM
  5. Black pipe questions
    Last Post: 02-21-2004, 10:24 PM
